Transformer question
I have a transformer here that I pulled from something, and It has a strange terminal setup. On the 'side' is a plastic screw terminal, with only two wires leading to it, one from the top of the transformer and one from the bottom, both on the same side. There is another screw terminal on the bottom, attached to the transformer case. This has a ground symbol on it.
Does anyone who has experience with these things know how this should be wired?
I wouldn't connect that if I were you...
Vive Le Tour!
Le Grand Depart July 6-8, 2007
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
