In Need of an INTERNET HTML MASTER GURU (Parallax Internet Netburner)
Well, This jurney into bits and bites, 1's and 0's has been a huge learning experience over the last year or more.· I have now come to a new hurdle that needs to be overcome.· I am using several pink modules that will be install all over the state.· They are being used in a Data acquisition system and there will be 17 variables displayed on an HTML page that is hosted by the pink module.· I have another server that is hosted at Startlogic that i want to be my data Recording hub.· Because the Pink module will most likely be behind firewalls, i will not be able ping them from the webserver at startlogic.· So here is my question,· The Pink has a couple of different protocols that it can use.· SMTP(for sending Email), UDP, and FTP(but i think that the ftp is just for writing pages to the pink?)·· Is there a way to have a script on the HTML page that will send its information to the Server at startlogic?· I dont even know if i am asking this right.·I have a page up right now on a pink.· Static data and not behind a firewall right now at 68.2.125.98:81 .· I need the values on the pink to be sent to the Server at Startlogic at least once a day, but more frequently would be better.
Any thoughts would be appreciated.· I know that the Pink will have to initiallize the contact because of the firewall.· How is the part i dont know.
It's Only A Stupid Question If You Have Not Googled It First!!
Chris Savage
Parallax Tech Support
You said that each "PINK" would be behind a firewall???
You need to find out what type of, and how powerfull of a firewall, as not all are the same..
Could you set up a VPN on the firewalls?? Or a DMZ????
A VPN would be the most secure and best way...
A DMZ would leave your PINK's open for any one to see the data/web page..
You need to decide how secure you want your data to be, and go from there...
With the above 2 options, your "SERVER" can poll the sites for data...
Bob
What kind of startlogic server / account do you have? Do you have one of their VPSes, dedicated servers, or shared hosting accounts? Is it a windows or linux based server? I have used startlogic before and have found their servers to be highly inadequate and their tech support to be extremely rude.
Harrison
For example, assuming that there is a Basic Stamp (or similar) connected to the PINK that does the actual data acquisition, you could retrieve the info from the BS2 (serial/usb) and send it via a script of some sort. Then a script on your Startlogic server could process the info as needed.
You should be able to use any web friendly scripting language, such as PERL, Python, Tcl, etc. Of course, your Startlogic account would need to support scripting, too.
