Measuring current
I am thinking of using a shunt for measuring loads up to +/-20A (boat battery), and feed this to the BS2.
The shunt gives me a voltage drop of approx. 50mV, which is quite small...
I guess I should use a dedicated A/D-converter for this, but do I need an OPAmp circuit, and in case, are there any pitfalls as the circuit must be powered by the same battery?
Maybe there are cheap dedicated chips for this that I might have overlooked? (cost is a factor)
Thanks!
/Anders
Thanks!
/Anders
You might take at this post this might help you out
Look at the bottom half of the page at
Increasing the Resolution
http://forums.parallax.com/showthread.php?p=622885
I hope this help you out with what you want to do
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 1/9/2007 2:00:19 PM GMT
The shunt could be placed on either the low side, connected to the (-) battery terminal or on the high side, connected to the (+) battery terminal. If it is on the high side, there are some very nice current monitoring ics available. For example, the MAX472 would convert the shunt voltage into a current that your Stamp could read using the RCTIME command. Then you wouldn't necessarily need an A/D converter. Here is a reference for that:
emesys.com/BS2rct.htm#B_current
Tracy Allen
www.emesystems.com
