Soldering Irons
I am debating between buying the xytronic auto-temp 137ESD which is $99.95 or the xytronic auto-temp which is $49.95. Just curious iwhich one you guys would recommend and why.
www.solderingdesoldering.com/xytronic/379.html
www.howardelectronics.com/xytronic/137ESD.html
Also I am wanting to do some surface mount soldering, What would be the must have tip for doing this? I was thinking the mini wave soldering tip might be good since on this page:
www.solderingdesoldering.com/xytronic/tips.html
It says it is designed for soldering surface mount IC's. There is a 2mm barrel one and a 1.6mm barrel one, not sure which would be better though.
This is a very nice soldering station you can use different tips also have surface mount IC's tips
i have one of these units and i am very very happy with it Temp control is the best thing about it
When you order it talk Shawn he is very help full also ask about th Solder Roll Holder that is also very nice
I think that you be very happy with it I know that i am
I hope this help you
··Thanks for any·
Sam
Temp controls·are the·temp set and temp read out which are the best thing about it i think
www.howardelectronics.com/xytronic/137ESD.html.........·
·This is a very nice tip 1.6mm barrel one
·You will have about··as much fun as these two are having·
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 1/6/2007 10:39:38 PM GMT
the one thing that my research clearly identified, was that there is no better source than Howard Electronics... Everyone just raves about how friendly and helpful they are (very important when buying any kind of tool!)
I recommend Howard Electronics also...Very helpful people.
Eric
for me...that and a good magnifying glass
Have fun assembling!
kenjj
Paul Baker
