Strange oscilloscope functions — Parallax Forums
John BondJohn Bond Posts: 369
edited 2007-01-06 11:55 in General Discussion
Hi Guys
I’ve had a Parallax Optascope for a while.
When I first used it, I noticed that the 500mv function gave the same reading as the 1V (1 volt per graduation). I use it manly for fault finding so this wasn’t a problem.
Last Sunday, I was monitoring a wave form and I noticed the display of the waveform didn’t increase above 10V, regardless of what voltage the actual waveform was. I don't think I've ever measures a signal larger than 10V before...
Are these problems:
········ A hardware bug?
········ Something in the Windows software?
········ A fault with the device?
Kind regards on this glorious hot humid·day in Kwa Dukuza - South Africa.
John Bond
  • John R.John R. Posts: 1,376
    edited 2007-01-05 15:02
    Based on memory from other threads, I believe that the Parallax o'scope caps out at 10 Volts. I also believe that there is a voltage, not much above 10, that will damage the 'scope.
    John R.
    8 + 8 = 10
    edited 2007-01-05 17:34
    John R. is correct…The input voltage range is -10V to +10V (20 V range peak to peak). If you go much above or below that you could damage the scope. I have never tried the 500mV/1V before, however we do have updated software coming very soon. Take care.
    Chris Savage
    Parallax Tech Support
    edited 2007-01-05 23:37
    If you need to go above +10V or below -10V, you can follow this link on what's needed for a X2 probe... Just remember that the readings you "see" on the scope will be 1/2 of what they actually are.
    http://forums.parallax.com/showthread.php?p=617175
    Beau Schwabe
    IC Layout Engineer
  • John BondJohn Bond Posts: 369
    Sorry Guys
    I had the figure 20 Volts stuck in my brain, not 20v peak to peak... Well, I took it to 32 volts for a short period and it still works fine!!
    Regards from Africa on this hot sunny Saturday.
    John Bond
