Martix orbital LCD's — Parallax Forums
The CaptainThe Captain Posts: 60
edited 2007-01-03 21:41 in Propeller 1
Has anyone had experience in programming this with the Propellor. I'm asking because i'm thinking about getting it for when the Hydra System comes out.
  • Oliver H. BaileyOliver H. Bailey Posts: 107
    edited 2006-09-01 02:43
    I use Matrix Orbotal in all of my writings and teachings. They are excellent displays and work very well with the Propeller and SX. There are RS232 and I2C versions. I use the I2C versions because they can share the same address lines as the boot eeprom for the propeller.
    Oliver
  • ianmceianmce Posts: 1
    I am glad hear that someone has interfaced these displays to work with the prop. I have used the 2x8 Matrix display with the BS2 using the i2cout command, but recently decided that my project needs more power so I have moved the project to the Propeller and have been unable to get anywhere with the i2c object posted in the object exchange. Any help or sample/example code would be greatly appreciated!
    Ian
