Question about division??
Ok....Mike...I know you will answer....but anyone else can as well.
Say I want to divide some moving data.
I don't necessarily care about the information below the decimal.
Will the propeller divide a mathematical problem that will result in a Floating point result? (without using a floating point calculation)
If so....what will be the result?
If not....well we know the answer to that don't we.
(especially Mike...... if you answer)
James L
James L
So...as I read it....if it is not a whole number result, the calculation wouldn't work.
But I'll look for the Propeller guts posting.
Thanks Mike...(as usual)
James L
mov temp,dividend shl temp,#2 ' multiply by 4 add dividend,temp ' add to get * 5 shl dividend,#1 ' multiply by 2 to get * 10
