ASM wont work...Help Please !!
Hi all !!
I've just beggining trying to understand assembly code, and I try with this.
Talking some PWM examples from Counters doccument, I want to·dimmer two differents LED at· different pins, I just write this simple spin code trying to use two cogs one for each LED, like still I can't see..how to pass different pins from spin to asm code,·I duplicate twice the PWM code with differents pin assigment, but this wont work !!.
First question is : ...what is the concept ? that I'm not seeing ? If I'm starting only two cogs with different pins ...why it seems to be that the first call to PWM1.go never returns..·and let start the PWM2 object ??
Second question is :· The parameter address is the only way to pass data from spin to asm started cog ?, I'd try to understand FullDuplex Serial object...where you must pass some·variables (like rxpin, txpin, mode, etc), and I can't, these variables appears "for me" like from the "sky" in the cog. (making· "understood" some calculations with PAR register...)
In this PWM example @parameter address, is passed to the cog, and then taken by vallue variable...but·it is only one...how to pass two variables ?
This is the code that I'm talking.
Thanks in advance for your time !!
Regards
Alberto.
CON _clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
R : "PWM1"
B : "PWM2"
PUB Vamos
R.go
B.go
repeat
VAR long parameter
PUB go | x
cognew(@entry, @parameter)
repeat
repeat x from 0 to period 'linearly advance parameter from 0 to 100
parameter := x 'a constant here locks to value x percent high
waitcnt(1_000_000 + cnt) 'wait a little while before next update
DAT
org
entry mov dira, diraval 'set APIN to output
mov ctra, ctraval 'establish counter A mode and APIN
mov frqa, #1 'set counter to increment 1 each cycle
mov time, cnt 'record current time
add time, period 'establish next period
:loop rdlong value, par 'get an up to date pulse width
waitcnt time, period 'wait until next period
neg phsa, value 'back up phsa so that it
jmp #:loop 'loop for next cycle
diraval long |< 6 'APIN=6
ctraval long %00100 << 26 + 6 'NCO/PWM APIN=6
period long 100 '800kHz (1.25µS period) (_clkfreq / period)
time res 1
value res 1
VAR long parameter
PUB go | x
repeat
DAT
org
diraval long |< 5 'APIN=5
ctraval long %00100 << 26 + 5 'NCO/PWM APIN=5
time res 1
value res 1
Regards
Alberto.
you will also need some stack space set aside for it
cognew(R.go, @stack_array)
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
Thanks for your help.
I'd try with this...but doesn't work
Is this correct·? .. only one LED continue fadding ..like in my original code....
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long Stack[noparse][[/noparse]20] long Dstack[noparse][[/noparse]20] OBJ R : "PWM1" B : "PWM2" PUB Vamos cognew(R.go, @Stack) cognew(B.go, @Dstack)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Just see my original code, it's like you said but doesn't work.
With :
PUB vamos R.go B.go· Please !! read my first question to see all original code posted. Only R.go works and never return.
Regards
Alberto.
PUB Vamos
R.go
B.go
repeat <
Maybe try removing this.
Just a SWAG
Charlie
repeat repeat x from 0 to period 'linearly advance parameter from 0 to 100 parameter := x 'a constant here locks to value x percent high waitcnt(1_000_000 + cnt) 'wait a little while before next updateThis is an endless loop,·you never return to the main program to execute the "B.GO" statement.
Nico
I'd try that ...but stil wont work...
Nico.
You're right with the effect, but I'm starting a new cog !! in B.go...first "go" is not the same as 2nd.....
And this simple code works.
{Pru1.spin} VAR long Stack[noparse][[/noparse]9] 'Stack space for new cog PUB go cognew(Toggle, @Stack) PRI Toggle ' BLINK LED dira[noparse][[/noparse]16]~~ 'Set I/O pin to output direction repeat 'Repeat the following !outa[noparse][[/noparse]16] 'Toggle I/O Pin waitcnt(clkfreq / 10 + cnt) 'Wait{Pru2.spin} VAR long Stack[noparse][[/noparse]9] 'Stack space for new cog PUB go cognew(Toggle, @Stack) PRI Toggle ' BLINK LED dira[noparse][[/noparse]23]~~ 'Set I/O pin to output direction repeat 'Repeat the following !outa[noparse][[/noparse]23] 'Toggle I/O Pin waitcnt(clkfreq / 20 + cnt) 'WaitIn fact, the problem seems to be, the repeat loop into the original code, but it hasn't the same effect, into this last code.
When I call "R.go" in the spin version it start a new cog, and continue running from it in spin, then return to the Main method, but when I do the same with the assembler code, it wont return !!
WHY PLEASE !! How to solve this ???
My target is to fade two differents LED,·at different pins, and with different speed, just only to learn, for future objects.
Regards.
Alberto.
EDIT: All wired is fine, the last code works with the demo board LED, Pins 16 and 23, when the first post code, is executed, only one LED works fading.
Envio editado por (BTX) : 12/27/2006 4:20:40 AM GMT
I think what we are not seeing here is the fact that each oject is running a cognew(assembly with Stack space) AND some spin(without Stack space from the TopObject).
Also, each par return is going to write to one global variable"Paremater"
BTX,
Try moving:
· repeat
··· repeat x from 0 to period········· 'linearly advance parameter from 0 to 100
····· parameter := x·················· 'a constant here locks to value x percent high
····· waitcnt(1_000_000 + cnt)········ 'wait a little while before next update
: up to the top object and monitor your variables from there.
Post Edited (bambino) : 12/28/2006 4:35:07 PM GMT
Thanks for the suggest, I did all test that I can imagine, and never got a correct work for this.
After 3 or 4 days trying, I was getting some frustrating, just do it, only for learn to deal with cogs, and some of asm code.
I thought that it could be a simple task...but nobody has solution for that problem...It seems that Parallax people is at "vacations" or similar and can't help...and, at this morning (here), I can solve it.
Just about a few minutes I get the correct work...I've now the solution....but I'm waiting to finish a complete task to post it code.
1- The problem solved code.
2- A demo code, of how to fade 3 LEDS (RGB) at differents rates, at different times, and at different pins.
Thanks again.
Regards.
Alberto.
PS: Chi vediamo dopo...
And yes I am glad to hear from anyone actually, I thought I might have become a ghost writter.
Tell me, was it this
repeat repeat x from 0 to period 'linearly advance parameter from 0 to 100 parameter := x 'a constant here locks to value x percent high waitcnt(1_000_000 + cnt) 'wait a little while before next updatecausing your problem?
·The answer is:
PUB start(Level,Pin) : Pass Stop Pass := (Cog := cognew(Auto(Level,Pin), @Stack) + 1) PRI Auto(Level,Pin) | x cognew(@entry, @Level_Cog) Level_Cog := Level pin_cog := Pin repeat repeat x from 0 to period 'linearly advance level_cog from 0 to 100 Level_Cog := x 'a constant here locks to value x percent high waitcnt(1_000_000 + cnt) 'wait before next update DATSo when you call "start", it returns, an let original spin code to continue running.
If you run Auto method like me "before", it never ends....simple but my confusion was that I have one cog for asm code and now I have one more to lunch it. In a minutes I'll be uploading final RGB LED fade code.
I could say that is a "mix" of many answers...that I have.
Be patient....here's is 15:15 and I've not lunch...still....
Regards.
Alberto.
Here's the final working code !!!!
Regards.
ALberto.
Now it has a bit more to play, Using the unused variable, you can fix the bright at each LED.
Take a look at the code now and try it.
A good question for experts could be .....is it·possible to do the same ..but with no so many cog's ?? easily ........
It is too much, to fade 3 led, using 6 cog's...
I think to include the "repeat loops" into the assembler code.....but it sounds me, hard to do, while maintain the counters working.
And it seems a commonly serial programming....just not for propeller.
Regards.
Alberto.
Here's the code:
You are actually doing 6 independent functions, but one of them is being done by a CTRx register with your assembly routine doing the reloading of the PHSx register. It would be possible to combine the PWM and fading functions into one cog. You have:
:loop rdlong value, par 'get an up to date pulse width waitcnt time, period 'wait until next period neg phsa, value 'back up phsa so that it jmp #:loop 'loop for next cycleYou could count periods and decrease the count with each period (or something similar):
:get rdlong value,par ' Upper word has pulse width mov delta,value ' Lower word has period decrease shr value,#16 and value,mask and delta,mask :loop waitcnt time,period ' Wait for period neg phsa,value ' Restart pulse width sub value,delta ' Decrease pulse width tjnz value,#:loop ' Stop when width is zero jmp #:get ' Start over again mask long $FFFF period long 100 value res 1 delta res 1 time res 1This only goes from on to off. You can add another loop that goes from off to on and stops when the width is the same value as supplied in the upper word of the long passed to the routine.
begin mov temp,par ' address of first long rdlong value1,temp add temp,#4 ' address of 2nd long rdlong value2,temp add temp,#4 ' address of 3rd long ' ...... ' more if you need itI understand perfect your example.... I wrote that could be possible to do some similar, but at this point of my learn.. I wont, cause I was 3 or 4 days to get it work, "with 6 cogs".
(Hope you understand me).
In fact, I was discover your example method, to pass many variables to the asm code, but you write it generically very well !!
This is my first try in asm...I took the CTRs example and modify it a bit.. I'll be continue trying every time I'd have some time...
Thanks so much again
Alberto.
