Question about graphics+tv RAM consumption
A question about graphics and tv objects:
In the demo for graphics there is the amount of $3000 + $3000 memory bytes reserved. - There is not much left for my application.
I already understood, that you need less memory, if you reduce the number of tiles. But I would like to have the resolution.
Is there a possibility having less colours and need less RAM? I have to admit, that I don't understand, how the TV system is working.
Is there an explanation anywhere?
Many thanks for some help!
Christof
Christof
Some eat a lot of RAM while others don't, like Chip's TV-text terminal object which needs very little space.
I'd look around the Object Exchange first to see whats out there already.
· If you only need black & white, my video overlay object only uses 6K for a 256 x 192 pixel screen.
· It will generate video even without the overlay circuit.
· http://forums.parallax.com/showthread.php?p=618061
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
I've seen some screens of it. You could do some nice B-W graphics with it.
Chip has a Object that does text in color and only takes 3k if I remember correctly.
The BitMap graphics object that you find in the propeller demo just takes up too much RAM to be useful for most designs.
I have now found out, that it is possible to use only one buffer and get the graphics to write directly into the viedeo ram:
'gr.setup(x_tiles, y_tiles, 8*x_tiles, 8*y_tiles, bitmap_base) ' original
gr.setup(x_tiles, y_tiles, 8*x_tiles, 8*y_tiles, display_base) 'no double buffer
With this you need only half of the ram, but the picture flickers of course.
Bean, will your driver work with the graphics object?
Christof
Post Edited (Christof Eb.) : 12/21/2006 7:52:14 AM GMT
I looked at the graphics object code, I'm pretty sure it is for 4 color/tile mode only.
Bean.
For an example take a peek at my demo www.seemeride.com
Hope this helps.
You might run into some really nasty flickering.
But yes, It does save you some nice and much needed space.
Are there engines in the public domain that use more than 2 color bits per pixel?
Frank
