sx48 and a "vpp generation failed" error msg — Parallax Forums
nick bernardnick bernard Posts: 329
edited 2006-12-22 17:31 in General Discussion
i checked out a previous thread http://forums.parallax.com/forums/default.aspx?f=7&m=139996&g=140150#m140150
my +5vdc seems fine, my header is identical to serveral other successful projects, and my xtal is very close to the mcu.
pin2 is connected to osc1 and pin3 to osc2 on the sx-key.
when i looked up www.parallax.com/dl/docs/prod/datast/SX48BD-Data-v1.5.pdf for the pin assignments i noticed that i may have soldered the sx48 upside down.
con some confirm?
ps the flash made my solder job look much worse than it is and i've already tested the device for solder bridges.
pin1 is upper left on pcb, circle is bottm left on sx48
are you supposed to supply every vdd and vss pin?
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
Post Edited (nick bernard) : 12/18/2006 6:11:02 PM GMT
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2006-12-20 01:25
    Nick,
    I'll confirm it for you. You need to position your chip 90 degree clockwise from how you have it shown. I confirmed this by examining an SX48 protoboard in addition to the document you referenced. When positioned with the text upright (as you have it shown) the oscillator pins will be found at the bottom edge of the chip. But the text is not what you should use as a reference. Use the dot for proper alignment rather than the text. The dot is your friend! It should be positioned in the upper left hand corner for the board orientation you have shown.
    Also, it is good practice to connect ALL of the power pins. Multiple pins are provided for good electrical performance which includes allowing for the rated amount of current to flow through those tiny pins. It is possible that your circuit will work just fine without all of them being connected. Just keep in mind that whenever possible it is a good idea to connect them.
    - Sparks
  • nick bernardnick bernard Posts: 329
    thx sparks, i incorrectly assumed the logo and text was gospel. oops
