Oscillator problems
I am having some serious problems when trying to drive my SX28AC/DP's without the SX-Key.
I have tried several 50 Mhz resonators ,with OSCHS2 and OSCHS3,
and also a 4 Mhz resonator with OSCHS2 and OSCXT2,
as well as· the 75MHz TTL oscillator with OSCHS3.
Every time the chip stalls. However, when I use the SX-Key to generate the clock signal, everything works fine. Also, if I connect a resonator, and the SX-Key afterwards, without having it generate a clock signal, everything works fine. I am having this problem with·all my·SX28 chips.
Does anyone know where the problem may come from?
Thanks in advance for any help.
For 5V use BOR42 and see if that fixes it.
This is a fairly common problem caused to the rise time of the power supply to the SX chip.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
I think it may be the oscillator circuit in the SX chip, but I don't see how three different chips,
two of which have not been used before have the same problem.
Any ideas to what may cause this?
Post Edited (Mr_Nuke) : 12/22/2006 3:19:53 AM GMT
Bean.
RB.0 : 470 Ohm ---- LED ---- Vdd
RB.1 : 470 Ohm ---- LED ---- Vdd
RA.0: (TX)·---- T1IN (Max2325)
RA.1: (RX) ---- R1IN (Max2325)
RA.2: (CTS)---- T2IN (Max2325)
RA.3: ----·!INVALID (Max2325)
The datasheet for the 2325 transciever is here : http://datasheets.maxim-ic.com/en/ds/MAX3233E-MAX3235E.pdf·. I have everything connected on the SX-Tech board, and I am not using the other I/O·pins as of yet.
This is the code containing my DEVICE directives:
I'm trying to use this with a 50 Mhz resonator. I've also tried HS1 and HS2 as the oscillator mode.
When I power up the chips with a resonator and without the SX-Key, they start normally, but they stall after a few seconds. I need to disconnect the power in order to get the chips restarted. The reset button doesn't help.
When I power up the chips with the 75 MHz oscillator (output to OSC1, w/ OSCHS3), they start up fine and halt after a few seconds. Again, I need to disconnect the power to get them restarted.
All the three SX28's I have behave in the same manner.
Does anyone have any experience with this issue, or any ideas that would get these chips going?
I just found out that everything works fine without the SX-Key if I remove·BOR42 from the device line. Any ideas on why this would cause a problem?
Post Edited (Mr_Nuke) : 12/22/2006 5:31:36 PM GMT
There is another factor, the internal feedback resistor.
If it is disabled [noparse][[/noparse]the default is enabled], it might help to place a resistor [noparse][[/noparse]say 1 meg ohms] in parallel with the resonator. See page 231 of Guenther's text where it says, 'if /IFBD is cleared,an external resistor must be used.' or take a look at the SX28 PDF for the FUSE details.
Also, it would not hurt to try OSCHS2 or OSCHS1 with the resonator. These setting provide less power to drive the resonator and that my eliminate the latch up.· You should try to run with the least amount of power driving the oscillations.· I am not sure that OSCHS3 is a good fit with a TTL oscillator.
When you remove the Brown Out at 4.2volts, what value do you replace it with?· It might be that the Max232 is drawing enough current to pull the SX below 4.2volts.· The fact that changing the Brown Out line of code is pointing toward a power line problem -- needing better·filtering for ripple or lowering the brown out threshold.· The SX28 can go quite a bit lower [noparse][[/noparse]2.6 or 2.2volts].· But others have had trouble when turning off the brown out completely.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 12/22/2006 5:46:42 PM GMT
The MAX232 document that I have indicates a mere 8ma is required, but that doesn't take into account the noise it generates from the voltage multiplier circuitry that makes the 12volt. The regulator only regulates incoming power.
The rule of thumb is that every chip has 0.1uf between Vdd and Vss at the chip to isolate the noise it internally generates when switching or whatever. A regulator will never catch that.
Since the MAX232 is on the regulated side, that rule applies.
