Unused methods
I heard from someone on this forum that unused methods in spin are not included; that is, the compiler chucks
them out.
In my tests just now, that doesn't appear to be happening. Is this supposed to? That is, if I have an object
foo with methods m1, m2, and m3, and I use it in an object bar but I only use m1, should the compiler not
include methods m2 and m3?
If I'm not messing things up (that is, the compiler includes all the methods whether or not they are used),
that's going to put a kink in my plans. Is this something perhaps that we can add to the compiler? If not then
I need to figure out how to get that effect for a FAT16 library I'm about to release; I would hate for people
who don't need directory traversal, for instance, to have to waste memory on directory traversal routines,
and I hate manual editing of code. Similarly, people who use putc() but not write() should not need to
include write().
Thanks for any help!
them out.
include write().
If you have an example of this that doesn't work, strip it down to its essentials and submit it as a bug report.
output of main. It does not require a string, however; a long sequence of simple assignment
statements also will be included.
You can trivially create an example yourself. Simply add any unused object to any
main you may have; the output file will grow by the full size of that object (and not just its
data portion as I would expect).
Or maybe I'm misinterpreting something.
I don't think you're misinterpreting anything. The compiler is supposed to optimize out unreferenced objects. I'll PM Jeff Martin about this.
thing will happen.
I've tried all sorts of things, including with real objects, and I cannot get any unused function elided at all.
Simplest test: build a main that has one empty pub and nothing else. Compile it, record the size.
Now stick at the top
obj
tv : "TV_Text"
Compile it and record the size. Nothing in TV_Text is used. Yet, you'll get every byte of code from
TV_Text in your main.
I thought, maybe if you don't use it at all it defaults to include everything. So use a single method from
TV_Text. You'll get the same (indeed a slightly larger) size.
Essentially, I cannot locate any evidence whatsoever that unused methods are eliminated. Every single
time I add a method to a subobject, even if it is completely unreferenced anywhere, the overall size
grows.
Chip Gracey
Of course this leaves library builders in a quandary; we want to provide a large set of methods
for people to use, but we don't want people who only use a small subset to pay the memory
price of all the methods. And there's no automatic way for us to figure out what methods are
actually used.
Is there any chance a new version of the tool could do what (apparently) many people expected
it to do, and simply not include code that's unused and unreachable? If nothing else, this will
quickly and effortlessly make a lot of current programs smaller.
Thank you, Mike, for alerting me to this thread.· The answer is that·both of you are partially right.
The current compiler (and every previous version of it so far) does optimize some things, but the granularity is at the Object level, not the Method level.· This means, if your application includes two or more instances of a particular object, the compiler only uses one copy of the object's code, and multiple copies of the object's global variables, in the final application.· So, for example, using 5 instances of an object will include 1 instance of the object's code and 5 instances of the object's global variables.· I believe this is what Mike is thinking of when he mentioned that it optimized methods.
Optimizing out unreferenced methods is something we'd really like to do, but it horribly complicates the compilation process and we have not reached a point yet where we wanted to take on that task.· The compiler recursively compiles the objects into the application and every step of the way it does a binary compare of the object units currently included and throws out duplicate code, patches addresses and move on.· That's the part that would have to change significantly if we had the added necessity to create an "intersection" image of an object based on every use of each instance of that same object.
Mike, I'm sure something we said, or didn't say, early on in the Propeller release led you to misunderstand what level of optimizing occurs in the compiler; I'm sorry about the confusion and apologize for that.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Your reasons are exactly why this idea has been floating around even before the release to make it optimize that way. Hopefully we can provide a solution to this someday.
--Jeff Martin
· Parallax, Inc.
One way to do it is to make your compiler take as an argument a hash table including the
methods that are needed (indexed by file name and method name). Every time you look
up a method name, make sure it's in this hash table. If it's not, mark the current
compilation as invalid, add it to the hash table, and continue. Every time you compile an
object, only include those methods marked in the hash table.
At the end if the compilation is marked as invalid, just repeat it with the updated hash table.
This way you'll throw away precisely the same methods every time, so your binary comparison
and address patching will still work. And the changes to your existing compiler are probably
pretty minimal (just throwing a loop around it and adding a hashtable of used methods).
(I used to write assemblers this way; just run the assembly process multiple times, if you
see use of an unreferenced symbol, treat it as zero on that pass and mark that pass as
failing, and repeat until you stop failing. It may not be the fastest way to go, but it
eliminates all the separate code for multiple passes.)
I'm sure there are a lot of complexities that I am unaware of in this case, though.
