question about Memsic 2125 Dual-axis Accelerometer and force reading
I want to use the 2125 to detect when a wheelchair bumps into something. From playing with it the X and Y outputs always show the tilt. The demo will indicate a constant gforce if I hold it at an angle. What is the best way to determine what I would call instantaneous gforce or a bump. Would you take the force reading and subtract it from the previous reading to get a difference that would indicate the direction it was bumped from and how hard?
- James
- James
See http://math.ucr.edu/home/baez/physics/General/jerk.html for a little discussion on force, acceleration, jerk, etc.
David
are anything that deviates from the normalized setting.
See:
http://forums.parallax.com/showthread.php?p=600561
http://forums.parallax.com/showthread.php?p=605325
Beau Schwabe
IC Layout Engineer
