how much current can I draw from the Vin and Vdd terminals?
I want my Basic Stamp to drive a 4-bit counter (SN7493) and a 4-bit latch (SN7475). Can I use the Vdd or Vin terminal on the Board of Education to power those 2 chips?
By the way, what exactly is the difference between the Vin and Vdd terminals?
lets see what this does... KA BOOM (note to self do not cross red and black)
Here is what I mean - I can run 4 servos off my BOE without a problem - BUT - I can't run my stepper off that same power source because A) it requires to much power
The short answer is to look up the specs on the Parallax web site. The reason I say that is because alot depends on what you are trying to do and what you are trying to run. If in doubt you can always email the tech guys.
Of course if there are questions about specific things posting is a good idea, but a question like you posted leaves a lot of wide open debate.
If you want a more specific answer it depends a lot on what you run for power. My stamp uses a 9 volt power supply but can run on 6 to 12. So if you figure you incoming power and tap into that you can get more power. If memory serves a stamp uses 5 volts, but it is recommened that you always use seperate power source for the stamp and components so that the Stamp doesn't brown out, depending on which stamp it could take upto 24 volts max.
Thats a long way of saying use two powers sources and the stamp takes at least 5 volts.
