board of education working but not - bad LM2940CT?
I have a BOE Rev B with a BS2 mounted.· When powered up, the green power LED does not come on, and I get no 5 V at the Vdd terminals bordering the breadboard, however I do get 5 V at the AppMod Vdd socket and the Vdd pin on the BS2.· Program runs fine.· I could not find BOE Rev B schematic on parallax.com, but did find it for Rev C.· I'm suspecting the LM2940 is bad (no voltage at it's inboard pin), but the on BS2 regulator is giving me the 5 V at the chip and AppMod.· Please confirm/deny, and point me to the Rev B schematic.
Thanks !!!
Charlie
Thanks !!!
Charlie
·· That is correct.· On the Rev B BOE the AppMod VDD came from the BASIC Stamp on-board regulator.· It does sound as if your regulator is damaged.· I hope this helps.· Take care.
Chris Savage
Parallax Tech Support
Just a quick question, everything is disconnected from the board so it's simply not shorted out at this time?
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
Charlie
