12v Battery voltage regulation
I have a battery operated project that uses stepper motors with driver boards (interinar Bsd-02, www.interinar.com) being controlled by a propellar chip. The motor driver boards have regulators built on to them rated from 7v to 30v. the entire device will be powered from a 12v battery. I plan to use a LM2937ET-3.3 Voltage Regulator for the propellar chip and a LM2940CT-5.0 Low Dropout Voltage Regulator for any 5v accesories i have. Is there any reason I should regulate the voltage from the battery before the stepper driver boards?
Owen
Owen
Such devices are a major reason for regulation.
If the three lines all have separate regulation, you will probably be fine.
The steppers may be a major source of noise that might otherwise interfer with the Propeller and control circuits.
You should try to avoid ground loops by having one 'star-like' ground network topology or a simple line [noparse][[/noparse]a to b to c to d ].
Keep it simple and if there is any trouble, the trouble shooting will be simple.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
