Problems with DS18b20 temperature sensor
Hello Guys,
I've searched the posts and cannot find a solution for my problem.· I am building a multiple sensing thermostat with the BS2p24 based on John Williams 2000 Nuts and Volts article on using multiple DS1820 devices.· Used 2 DS1820 sensors in 1 wire configuration with no problems.· Bought 4 new DS18b20 sensors (can't·find DS1820s) and cannot get a correct temperature reading.· I can read the serial number no problem but the temperature is way·off.· When I plug the DS1820s back in it works great.··Should I be using the DS18s20 sensors?· Any help is appreciated.· Thanks.
-Walter
-Walter
The DS18B20 is a higher resolution device, so you need to use a different formula. That caught me up too, the first time I used one. Compare the data sheets.
' ---------------------------------------------------------------------------------------------- ' {$STAMP BS2pe} ' {$PBASIC 2.5} ' Tracy Allen, EME Systems ' DS18B20 (12 bit) program displays temperature, -55 to +125 Celsius +/- 0.1 degree ' single one wire device--the skip ROM command can be used. degC VAR word DO OWOUT 0,1,[noparse][[/noparse]$CC, $44] DO : OWIN 0,4,[noparse][[/noparse]degC] : LOOP UNTIL degC ' wait for done OWOUT 0,1,[noparse][[/noparse]$CC, $BE] OWIN 0,2,[noparse][[/noparse]degC.byte0, degC.byte1] DEBUG HOME, REP "-"\degC.bit15, DEC ABS degC/16, ".", DEC1 ABS degC */ 160 , " " LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Tracy Allen
www.emesystems.com
-Walter
Tracy Allen
www.emesystems.com
