Ping module question
Is there a way to modify the ping code to be able to start multiple ping sensor units at the same time and wait for all the responses and get the measured time before returning? I need to be able to monitor 4 or 5 sensors but don't want to use one cog per sensor or call one function per sensor in series because of the delays that would be added up. If the max wait time is ~50ms (max distance) and I am reading 5 of these in succession that would be about 250ms per ping cycle not allowing for more than 4 reads per second. I thought I saw a function somewhere that would start a timer that would measure a pulse on an input or multiple inputs, and wait for all of them to change before returning. I can't remember where I say that code.
- James
- James
I've been working on a robot project that uses the SRF05 sonar unit which is very similar to the PING unit. I had the same problem when I wanted to drive multiple sonars from the same cog. I wrote a new assembly driver that will monitor multiple sonar units simultaneously. It is currently written to drive 3 sonars although the code should scale up to 5 easily. I've also included·SPIN code that demonstrates using the driver.
One word of·caution, I'm using the DLP-PROP units which run at 96MHz instead of the 80Mhz that the demo board runs at. It should be obvious where to make the appropriate changes.
Hope it helps,
Chad
Post Edited (Chad George) : 12/11/2006 6:06:11 PM GMT
' Assuming you have 4 pings starting at pin 4 with pulldowns (say 10K) to ground: VAR long startTime, elapsed, started, pingCount PUB timeIt | x ' Start 4 pings going and record the pulse width for each in elapsed[noparse][[/noparse]x]. ' Units for pulse width are system clocks (normally 12.5ns). repeat x from 0 to 3 started[noparse][[/noparse]x] := false pingCount := 4 outa[noparse][[/noparse]4..7] := %0000 dira[noparse][[/noparse]4..7] := %1111 ' make outputs outa[noparse][[/noparse]4..7] := %1111 ' start pulse waitcnt(clkfreq / 100_000 + cnt) ' 10us pulse dira[noparse][[/noparse]4..7] := %0000 ' change to inputs waitcnt(clkfreq / 2_000 + cnt) ' 500us hold off repeat while pingCount ' wait until all pings respond repeat x from 0 to 3 if started[noparse][[/noparse]x] ' this ping's response pulse has started if ina[noparse][[/noparse]4+x] == 0 ' the pulse is now back to zero elapsed[noparse][[/noparse]x] := cnt - startTime[noparse][[/noparse]x] ' record the elapsed time pingCount-- ' one less ping to wait for else if ina[noparse][[/noparse]4+x] == 1 ' not yet started, pulse now high startTime[noparse][[/noparse]x] := cnt ' save the start time started[noparse][[/noparse]x] := true ' mark pulse as startedYou're absolutely right.· Easiest way to fix this is to initialize the elapsed array to zero in the loop where started is initialized, then test for·"ina[noparse][[/noparse]4+x] == 0 and elapsed[noparse][[/noparse]x] == 0".· Sorry
