sense small inductive changes from a coil, and use it as a sensor
I was looking at the Propeller object code site and noticed a contribution by Beau Schwabe (Parallax)·-· "sense small inductive changes from a coil, and use it as a sensor".
I would like to do this with a BS2. Has anyone done this with a BS2? Beau, can you modify your Propeller code to work with a BS2?
There are a few ways to sense small inductive changes... It would help if I can get a better feel as to what your exact goal is, before I make a suggestion.
Beau Schwabe
IC Layout Engineer
In that case, I'm afraid the inductor application you mention will not work the way you want.
It is based on resonate frequency response characteristics of a coil with the proximity of a metal object, and will not work for measuring current.
When measuring current flowing through a 120VAC power cord you must take certain safety precautions into consideration.
Off the top of my head, a solution is beyond my scope at the moment, simply because I don't have the experience with 120VAC to provide a safe solution.
Beau Schwabe
IC Layout Engineer
