Updates to StampDAQ coming for the New Year - Your input?
I keep getting the same requests for mods to StampDAQ over and over, so it's about time I guess for a version 2. Here is what will change:
- Greater selection of COM ports (those USB thingies add a lot).
- Ability to send data for up to 26 columns instead of 10
- Ability to GET and SET any cell's data, pretty easy to set up a loop or what not for a range. Many want to do real time collection and adjust values based on the spreadsheets values they provide.
Examples:
DEBUG "SET, C3,", DEC x,CR
DEBUG "GET, D4",CR
DEBUGIN DEC X
- Addition of TIMER directive for seconds (milliseconds) since last cleared instead of time of day.
- Re-doing the help files since I no longer use the software I used to make those.
- Using Install Shield for a single EXE installer.
- Suggestions and feedback welcome. A couple programmable interactive checkboxes or such?
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
Examples:
DEBUG "GET, D4",CR
DEBUGIN DEC X
-Martin
Martin Hebel
Showing up to school doesn't·mean you are a student any more than crawling up in an oven means that·you are a biscuit.
-Martin
Martin Hebel
