Source for black 'Header' connector on Parallax stamp boards.
Anyone know of a source for the black header type connector located next to the
experimenters area on the Parallax boards.. I need 24 and 32 pin versions.·
carline
Chuck Arline
carline
Chuck Arline
That is one such connector, you'll have to look at the specs on the board to get the pin spacing on the header to select the right connector, but that company has most of the popular sizes.
Roger Pierson
Senior Electronics Technicain
DTI Assoicates
www.jameco.com/Jameco/catalogs/c264/P149.pdf
2 12 pins: 200782CG
2 16 pins: 70720CG
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=200782CG&productId=200782
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=70720CG&productId=70720
Or, if you need the exact size, Samtec probably has them (they have just about any connector and probably where Parallax buys theirs).
www.samtec.com/
Kenny
