Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Vdd, Vss on QFP, all 4 of each required? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
T Chap
4,260
2006-11-30 22:19
edited 2006-11-30 22:24
in
Propeller 1
Updating libarary to incorporate the QFP. I already assigned 2 each of Vss and Vdd. It is a slight hassle to add 4 more pins to the symbol. Is two enough of each power pin?
Phil Pilgrim (PhiPi)
23,514
2006-11-30 22:24
Noise and ground bounce will likely be a bigger hassle.
Sign In
Register
to comment.
