This kind of heatsink — Parallax Forums
LightfootLightfoot Posts: 228
edited 2006-11-30 09:02 in General Discussion
Who sells this kind of heatsink (heatsink for two TO-3 devices)?
    edited 2006-11-26 06:31
    Have you tried digikey or mouser?
    - Stephen
    edited 2006-11-26 14:06
    By the looks of it, the pic is it.· It is drilled for all contingencies.
    Wished you'd have just added this to your previous Subject on this matter.· http://forums.parallax.com/showthread.php?p=617401
    Post Edit -- [noparse]/noparse][/i] I guess things got [i]warmish[/i], afterall? [i
    Post Edited (PJ Allen) : 11/26/2006 2:40:21 PM GMT
  • LightfootLightfoot Posts: 228
    edited 2006-11-26 15:43
    No, this a different device, the LM338K (TO-3 device). At full load those things get burning hot! Mouser does not sell them, neither does digikey.
    edited 2006-11-26 15:49
    maybe you could use two of these:
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G15816
  • metron9metron9 Posts: 1,100
    edited 2006-11-26 16:16
    try http://www.futurlec.com/
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
  • aalegadoaalegado Posts: 66
    edited 2006-11-29 19:56
    Mike Cook,
    I wouldn't connect that if I were you...
    Vive Le Tour!
    July 1 - July 23
    What types of heatsinks do they use for huge bridge rectifiers such as the KBPC2501?· I definately need one because it gets burning hot when·I pull heavy loads through it (my load was only three amps, imagine thirty!).
