Excercise your brain cells with this problem
I have a small battery operated thermometer display that runs from 2 1.5 batteries. 110ma hours
I am using a tiny13 that uses only 0.1uA in power down mode
The only way to wake up the chip from that mode is a rising or falling edge on its int0 pin
If I just use idle mode it takes 300uA so I have to use power down mode
I could use a big resistance value and a small capacitor to hold the pin low until the cap charges to pin threshold so the chip would wake every 5 seconds or so, but that is not as dynamic as I would like it to be because when the temperature changes it can take up too five seconds to see the adjustment.
I would like to make a circuit that could trigger the interrupt on a change in the thermistor resistance, rising or falling edge that way the chip could sleep for many minutes or hours or days and only wake on a change in temperature.
The interrupt trigger circuit should only take perhaps 20uA that would allow 6 months of battery life.
Any ideas?
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 11/29/2006 4:21:00 PM GMT
Any ideas?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
I think what I am really want it to do after thinking about it a bit more
Is use a tiny motion sensor that would trigger the interrupt from power down mode.
Using a simple pendulum and a + and - contact I could use a pin change interrupt as the pendulum would bounce between the contacts when the device was moved. I would then monitor on a more frequent basis until the temperature stabilized, and put the chip to sleep with the pin change interrupt.
I am just trying as an exercise to find the longest battery life possible and still have a dynamic response within a second of moving the object. that would mean if the object is on a shelf it would take zero power until it was picked up. I don't care to display the temperature when it is not in use.
Yes the change in the thermistors resistance would be more difficult to do with low power than a movement sensor.
It needs to operate down to 1.8V as well.
I can put the chip to sleep, and never wake up until someone moves the product.
