Counting Revolutions and Determining Direction w/Melexis 90217
All--
I have a rotating shaft turning somewhere between 100 rpm and (maybe as much as) 300 rpm. I do not care about the speed of rotation. What I want to know is how many revolutions it makes and in which direction. (It is a screw drive.) My thought is to use two Melexis 90217 Hall Effect sensors placed on each side of the shaft with a single magnet fixed to the shaft. One 90217 would count rotations and use a single Stamp input pin. A comparison of the two 90217 outputs·(using another Stamp input pin) would allow me to determine rotation direction as long as I knew which direction the shaft began rotating upon startup.
Of course, (I think) if I used three 90217 sensors, then I would not need to know the direction of shaft rotation upon startup.
What do you think of this idea? (The reason I would use multiple Melexis 90217 devices is solely due to Parallax's support of things they sell. A dual Hall-Effect sensor designed to provide both count (or RPM) and direction would doubtless make more sense if I knew anything about electronics.)
--Bill
You are what you write.
--Bill
Going clockwise 1....1........1....................1....1........1.......................
Going countercw 1........1....1....................1........1....1.......................
So counting the space between the pulses you would know the direction
counting 1 for every 3 pulses you would know the revolution count.
At 300 RPM you have 200ms per revolution.
200 ms / 360 degrees = .55 ms per degree
Spacing magnets at 0, 45 and 135 degrees
gives you (45*.55) ms (90*.55)ms and the balance of the 360 degree rotation ((360-135)*.55)ms
25ms, 50ms, 125ms
so you have a short, medium and long pause between pulses
short,medium,long is one direction
short long medium is the other direction
A bit of math to calculate the lengths of the pauses as they relate to each other and you have it done with one sensor.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
···· Use your two sensors and one magnet as you described. Then set up a quadrature counter in your stamp·program. You'll be able to both count number of revolutions AND determine· the direction.
·· I put a piece of sample code on my website:
··http://siskconsult.com/quadhicount.bs2
·Tom Sisk
Tom Sisk
http://www.siskconsult.com
AND the shaft would be balanced better, hence no vibrations!!!!!
Bob
Thanks for the ideas! They were all better than mine.
Tom, I saved your code. Thanks.
--Bill
Justin
sculpture and ceramics major
UMD
Duluth MN
