Heatsinking
I have a setup where a TO-220 power·mosfet transistor can carry 3 amps at·12 volts, up to 40 watts (36 to be exact).· What kind of heatsink should I use?· The FET is mounted on a PC board.
You've, doubtless, seen the sort that have the fins on them -- won't be enough (no way.)· What you need is a considerable piece of metal.· The fin-type might help, if placed between the device and the metal/mass.
You could try and just use the black-anodized piece screwed on and see how that goes, or nothing at all; it's not as though lives are at stake.· [noparse][[/noparse]Right?]· What's the worse thing that could happen (buying another transistor)?· For that matter, it could get hotter than heck and, for your intents and purposes,·"work."
If you want it to be cool to the touch, quite large.
The specification sheet should tell you want the thermal absolute limit is.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Assuming the "power mosfet" is rated at 3 amps and 12 volts, there is no conceivable way for you to get the device to dissipate 40 watts within those ratings.
I suspect the 36 watts is being described as the load that the particular mosfet can control.
A power mosfet when "on" typically has a D-S voltage drop less than one volt, at full load of 3 amps, that is 3 watts dissipation. Similarly, if the "on" voltage really were 12 volts, you're really not dealling with a proper power mosfet.
Cheers
Tom Sisk
http://www.siskconsult.com
I think that what anyone would/should take away from reading my previous post would be: give it a shot and find out what happens.· You can't reach for the gold ring if both your hands are shielding your stones.
Post Edit:· If it "works", then fine.· If it doesn't "work", then Stop.
Man -- Doc, it hurts when I do this.
Doc -- Then don't do that.
Post Edited (PJ Allen) : 11/24/2006 8:09:06 PM GMT
Look in the specs for Rdson, that is the resistance when conducting. Knowing that, take your load current, square it , and multiply by Rdson. That is the power you're dissipating. I think you'll find it to be very small. You may even find in the spec a note as to power dissipation capability in the un-heatsinked mode.
Also, take PJ Allen's advice........Try it. The old techs used to say if the MOSFET is not hot enough to melt solder, its probably OK. Well, realistically, you should be able to hold your finger on it when operating (something around 110 to 130 deg F)
Good luck.
Tom Sisk
[noparse][[/noparse]Just asking because you originally mentioned 12V, 3A.]
Generally there is a watt rating in the fact sheet. If you go above that, there is just too much heat and destruction.
While you may calculate that you want 40 watts, the device may sink only 5 or 10 watts. You have to put more FETs in parallel.· Often the voltage and amp ratings are maximums for duty cycles of far less than 100%.· So, when you add the two together.... smoke appears.
Look at the wattage rating.
Post Edited (Kramer) : 11/25/2006 9:44:11 AM GMT
