NCP7662 Voltage doubler calculate current output
I am not sure how much current this chip can output.
The datasheet:
www.datasheetcatalog.com/datasheets_pdf/N/C/P/7/NCP7662P.shtml
Says Power Dissipation (Note 2.) 720mW
So using it as a voltage doubler
The NCP7662 may be employed to achieve positive
voltage doubling using the circuit shown in Figure 9.
at 5.5V input and 11V output I would calculate A=W/V or A=.720/11 = 0.065A
Is that correct? I only need 9.1V. At 45ma, Right now we are using a voltage booster from Wall electronics but they are $15.00 each. The chip I am looking at is only $1.04 in 500 Qty
Its funny too I can't find that part on the On simi site but I got a quote on them from Rochester Electronics, LLC for 50 and 100 qty.
Think Inside the box first and if that doesn't work..
Think outside the BOX!
The datasheet:
Remember, POUT will be·< PIN.·
So if I take a stab at what I think you mean.
If I need 11V at 65 Ma i would then need 130ma at 5.5V so 5.5V * .130A = .715W within the parameters of the chip.
So the answer is yes I can run a 9.1V circuit that draws 45mA ?
··I wonder what you're trying to operate with this IC.· LEDs or something?· That could be done with the negative converter easily enough.· The cathode has only to be more negative than the anode.
· Sometimes you have to re-arrange what's in the box.·
Anyway He found some 6V to 12V DC-DC converters and in small quantities his price was 25 bucks ea. per hundred 15 each.
1.5W, 12V 125mA part PK1.5-D5-S12
http://www.v-infinity.com/adtemplate.asp?invky=94723&catky=328060&subcatky1=248699&subcatky2=285565&subcatky3=
They are out 3 weeks to get any so i continued to look.
I found some at a company called Wall something, I cant find it now on this computer, but they were a little smaller, like I said I know the current won't exceed 45ma and the ones he is going to test are 85ma I think. But they are 15.00 each and they had 5 in stock so he bought them.
So I continue to search for a dc=dc converter that perhaps we can build on a small circuit board for less.
The converters we have found have pins so to do it right we still should put it on a board for wiring as it is in automotive and a solder joint bouncing around unconnected to a board directly soldered to a pin on the converter simply is not a good idea. I think a small board and some tiny pc snap standoffs would work great.
Since a board is necessary and soldering anyway, I thought a chip like this one might just do it, if not enough power they could be doubled up I would think.
Suggestions on DC-DC converters welcomed...
Re-arrange what's inside the box then...
Post Edited (metron9) : 11/23/2006 4:58:22 AM GMT
· Usually when the Power Dissipation is listed rather than current it is because there is a variable voltage range.· When that happens the current rating will change with the voltage.· Ohm’s law will help you here.· Divide the Power Dissipation by your voltage and you’ll get the max current.· Take care.
Chris Savage
Parallax Tech Support
The output resistance is the parameter to looki at in the data sheets, and the data sheet will also have information on the ripple at the output as a function of current. For example, an output voltage of 10 volts and an output resistance of 80 ohms, will drop to 10 - (80 * 0.4) = 6.8 volts when the output current is 40 ma.
That same chip is available from Maxim and Intersil, I think with the ICL7662 prefix and also from NJU7662. There is a high efficiency version available (lower internal switch resistance) with a D suffix.
TI makes some very nice little voltage converters in DIP packages capable of one watt output, that cost around $5.
Is it possible to operate your tach at a lower voltage without using the zener, if the voltage is regulated? That is possible with the LM2917LM2907 tachometer chip.
Tracy Allen
www.emesystems.com
