Shocking question!
Here is a shocking question.
I am working with a prototype oil burner gun, like we use to heat our homes with here in the North East. I have a garden variety 120VAC to 10,000 volt transformer and the matching electrodes that is used in a typical burner to ignite the atomized fuel.
In the normal installation, the transformer sits directly on top of the electrodes with the terminals separated by a distance of about 3“ until ignition. ·The bent shape of the electrodes brings them closer to eachother in the burner chamber, and they spark when they get to about ½” from each other.
In my design, however, I do not want the transformer to be limited by these physical constraints, and would prefere to have the transformer somewhere else, a few feet away, and run wires to the electrodes where they can “do their thing”
Question:· How can I carry 10,000 volts (albeit, low amperage) across a couple of wires a few feet long without killing myself or others?
I simply want to run a wire from the transformer to each of the two electrodes.
Sparky
Expert in many fields, dumb as a stump with STAMP
I simply want to run a wire from the transformer to each of the two electrodes.·
Sparky
They're large enough that you'd probably NOT want to work with them (as I'm sure they do not bend easily).
At work, our UPS (building UPS) uses buss bars for interconnecting the batteries. This is mostly because of the current draw as the batteries don't quite equal 340Volts in total.
Is it the placement of the transformer that's bothersome? or is it the size of it?
You could put one in place that's half of what your current needs are and then put another one rated the same (half of original) somewhere else.
I wouldn't want to run 1000's of volts along a path where someone might thing (or not think) of putting their hands/feet....again, I don't have a solution but you might NOT want to fuss with it!
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Think Inside the box first and if that doesn't work..
Think outside the BOX!
Tony Ventura
Professor / Electronics Technology
Macomb College
Macomb County, Michigan
venturat(at)macomb(dot)edu·· (modified against spammers ;~)
hypertextbook.com/facts/1999/DeniseLai.shtml
http://www.msdignition.com/coil_blaster_8_8201.htm
a stock ignition coil can produce 15,000 - 30,000 volts. If you are looking to do it cheep, Do a tune up on your car (Plugs, WIRES, ect.) take the old wires, cut the boots off and go to town. If the stock wires are not cracked or hard they will work up to about 45,000 volts.
one other idea, goto an neon sign shop and buy some of there high voltage wire that stuff should do the job.
TC
We all make mistakes when we are young………That’s why paste is edible!
Steve
http://www.angelfire.com/80s/sixmhz/flyback.html
