usb to rs232 cable adapter
·I have a BASIC Stamp HomeWork Board. My computor hasn't got a serial port, so i got a usbto rs232 serialport adapter and it dosen't work. I've tried all the trobleshooting. When i run and identify, i get loopback- no, echo-yes. no tech help till monday. help!
Have u try different USB slot. cause mine after installing the driver my laptop still cant
detect the BS2. After switching to the slot at the back it works fine. I dont know why.
Maybe people at Parallax can explain it.
You shoul try it and see what happen.
Your cable should come with the driver. Make sure u choose the correct driver from the cd.
Take care.
But the biggest problem is that not all USB chipsets have all the RS232-signals needed for successful communication with the BS2.
Adapters using the FTDI chipsets usually works OK, though.
(Parallax sells some)
Adapters advertised to work with older serial PalmPilots or Psion PDAs should also work OK.
(Both needs those 'extra' signals)
If you can afford it, go for the Parallax one.
(If you want to use a cheapter shipping than is offered in their online store, just write a comment about it.)
Don't visit my new website...
Since all the BasicStamps and their fellow clones require a third RS-232 line, seems like a useful device.
If there isn't a device, how about a schematic for DIY?
I wish the new PDA's still had RS-232. The PalmPilot is a wonderful terminal for the BS2s.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
·· While it is true that not all USB to Serial adapters work, we have tested the Radio Shack unit on both Desktops and Laptops.· The only thing that I am aware of as far as problems is that you must have the latest driver from their website, and on laptops you often have to disabled the FIFO buffers in the Advanced Driver Settings.· Of course, we do provide an inexpensive solution.
Chris Savage
Parallax Tech Support
