VERY long division
How can I change the number of decimals the BS2 will calculate out?
The largest variable can hold several thousand characters, so can it go out a long ways?
Can it go to·1000 points out?
If not how far?
If not how far?
But if you need to hold a number in memory, the Stamp is quite limited on memory resources. What are you trying to do?
Tracy Allen
www.emesystems.com
A greater limitation than the capacity of the basic stamp to do this kind of division is the capacity of the sensor to provide high resolution data.
So, if you are using the Parallax GPS module and it is providing a 'word' of data, it isn't really useful to resolve data to a division greater than a 'word' can hold.· There is a limit to the accuracy of a GPS unit as well.
I could use a wooden ruler to measure a length to 1/32nd of an inch.· But this does not mean I can expect to know half the distance to 1/1000th of an inch.·
