Using Relay To Replace Pushbutton on a Handphone.
Hi all,
I am doing a project to program a relay to replace the push button on a handphone.
If i asign a pin to each of the button I will need 17 I/O pin. that's not enought from BS2.
maybe i have to sacrifice few buttons to make it posible.
Do anybody knows how to replace· pushbutton without using relays.This is the only method I
know cause I am newbie.
I would very much appreciate if you can tell me how.
· Azmi.
Post Edited (azmax100) : 11/17/2006 2:47:10 PM GMT
· Azmi.
What you need is a keypad encoder. Here is one but it's limited to 16 keys whuch is usually an ample number:
http://www.allelectronics.com/cgi-bin/item/EDE-1144/search/KEYPAD_ENCODER_IC_.html
Bruce Bates
<!--StartFragment -->
I already take a look at the link and download the datasheet.
What I understand after readind the D/sheet that the encoder is use to send signal to the stamp.
Actualy what I am going to do is instead pressing the h/phone button I want to program the stamp to dial
or use the function in the phone.For instance I want to use the MP3 from the phone so I will program BS2 to
press the button for me. I was thinking to combine this function with a remote control (IR Remote By Andy Lindsay).
Is it can be done with the encoder?
Maybe I miss something or not really understand what I've read from the D/sheet.
The keypad encoder is only used for READING a keypad, that's it.
If you're looking to send touch-tone signals, you want to use the DTMFOUT command.
Bruce Bates
A popular one is the 74HC595.
As for how to connect to the keys, that depends on the phone, really.
It may be possible to drive it with a transistor, or even directly from the outputs of the 595.
(difficult to tell without experimenting with the phone in question)
Don't visit my new website...
Actually I already done some expeiment with the relay and it's work fine.
I got the schematic from this thread http://forums.parallax.com/attachment.php?attachmentid=39247
I dont mind to follow Gadgetman suggestion to use the 74HC595 to get the extra IO.However
I don't like to use the relay cause i don't like the tick sound·and will take lot of space.
I want to make my project as small as posible. If I have to drive it directly from the 595 how am I going
to connect it. Can you provide me a schematic for that. I would very much appreciated for your help.
Thanks & Take care.
Azmi.
What you should do is look at how it works.
I assume one side of each switch is connected to some sort of IC in the phone, but the other side?
Is it driven low(Gnd) or high(+5V/3V/whatever)?
And what voltage does it need to consider it a keypress?
(Try a large Potentiometer, say 10Mohm or more, across the terminals and adjust it down while measuring the voltage across it until it registers a keypress)
www.allaboutcircuits.com/vol_3/chpt_7/9.html
- Stephen
Thanks Franklin & Gadgetman for your reply.
Gadgetman,
I will do as what u suggest and will let u know about the progress. I will do it this evening and let
u know. ( Malaysia time now is 1.00 pm) Hope u will keep on looking·at my post.
Thank you very much.
This forum need a lot of people like you.
Edited:
I·already made a·measurement with multimeter·on the pushbutton. It seem there's no·current flow
to complete the circuit. maybe its from·-tive·side.The circuit functioning even i connect with 10K resistor.
(that is the highest·value·resistor I have).
Hope u can guide me towards my project.
Thank you & take care
p/s·attached photo are the keypad. I have to peel the·button layer to solder the wire to the relay.
17·button·x 2 wires. It will look messy isn't it?
Post Edited (azmax100) : 11/20/2006 12:43:39 PM GMT
Please.
