Transistor Confusing Me
Well, that is not too surprising considering my knowledge of this stuff, but maybe some of you can help.
I have this transistor:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=210518&pa=210518PS
The plan is to use it to drive a 12VDC motor.· Before hooking it up to my BS2, I decided to try it out first to make sure I understood how it worked.· To do this, I connected the collector to Vdd, and the emitter to Vin via a LED.· Vin at the moment is 9VDC b/c I am using a BOE and the onboard 9V battery.· I origionally connected the base to Vss (wanting 5vdc to activate the transistor), but that didn't work.· So, I tried connecting the base to Vdd.· That worked.· Now, that part does not worry me too much because I was probably just confused about what polarity was needed to trigger the transistor.
However, I do not want to fry my stamp when I hook the two together.· So, I measured the voltage between Vdd and the base and it is reading ~6.25 VDC.· Not sure why it isn't 9VDC???· Also, the transistor didn't trigger when connecting Vdd to the base through my meter because the LED did not turn on.
So, I guess my questions are:· 1. Is my setup so far OK, or am I at risk of frying something.· If so, 2. How can I safely hook it to an output pin of my stamp?
Thanks!!
Thanks!!
- Stephen
The Process control text from Parallax illustrates how to drive a 12V fan, though due to the nature of the fan, the diode for protection is not present in all drawings.
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
So, with the 220 ohm resistor, I am not running any risk of damage to the stamp, correct? If I run two or more of the transistors in parallel to keep heat down, do I use 1 resistor for all three, or a resistor for each?
Also, about the motor. How should the diode be connected? I am not really sure what you are reffering to. Also, you may need to know that I will be using the transistor(s) to provide a 0-12VDC powersource to a relay, which then goes to the motor. The relay (actually 2, 1 for + and 1 for -) will be used to reverse polarity to reverse the direction of the motor.
Thanks again for your help so far!
Right click on filename
Change name to kickback.avi
Save file
Double click to run movie
Then explore the java applet at this site to learn more about how electrons flow through all kinds of devices
http://www.falstad.com/circuit/
This link pops up a java applet when you link to it with a default circuit running
You can change components, look at all the built in circuits, save circuits to text files and reload them.
Think outside the BOX!
Chris Savage
Parallax Tech Support
