Pin redefinition
· Hallo to all. I'm in the early stages of learning to program the sx28·using assembly. I've made a few programs so far but I've reached a point where I have to find out how to perform a task which I was avoiding to tackle for some time.
· In order to make a pin easier to work with you can do this:
··· led1· EQU· RA.0
··· led2· EQU· RA.1
What I would like to be able to do is to redefine it some way. For example:
··· working_pin is led1
··· working_pin is led2
I know I don't have to explain to you how this could be helpfull.
Thank you very much.
··· led1· EQU· RA.0
··· led2· EQU· RA.1
it is not fully clear to me if you want to re-define a port pin at run-time, or at assembly-time.
SASM accepts "EQU" and "=" for defining constants, so at the first glance,
led1 EQU RA.0 and led1 = RA.0
seem to have the same effect.
The difference is that a constant defined with an "=" can be re-assigned at another location in the source code. When you try the same with "EQU", SASM will flag an error.
Greetings from Germany,
G
·Again thank you very much.
