I·can get the 7219 do display numbers just fine, but for the life of me I cannot get it to put a decimal point on the display.· does anyone know how one would accomplish such a feat?··
If you type in "decimal point and MAX7219" in the Google search located on the Parallax website www.parallax.com·it will come up with Experiment 29, which will show you how to use the decimal point.
Hello, · ·· The code from the following project makes use of the Decimal points for non-decimal point use, but shows how easy it is to turn one on for a value and conditionally.· I hope this helps.· Take care.
Dave
Dave Andreae
Parallax Tech Support·
http://forums.parallax.com/showthread.php?p=552892
Chris Savage
Maxdisplay:
· FOR index = 5 TO 1
··· SHIFTOUT DATA_n,CLK2,MSBFIRST,[noparse][[/noparse]index]
··· temp = dispVal DIG(index-1)
··· IF index <> 4 THEN· skip1
··· temp = temp + 128·············· 'Add decimal point to no 4 (00.000)
skip1:
··· SHIFTOUT DATA_n,CLK2,MSBFIRST,[noparse][[/noparse]temp]
··· PULSOUT load,5
· NEXT
RETURN
