to John Abshier about NES code
samsn4
Thanks for the code, got a couple of questions:
note: I'm using the demo board
1. When connecting the controller yellow/data is at PO, orange/latch is at P1, red/clk is at P2, white/power is 5v, and brown/ground is at Vss?
2. If question 1 is true, and i'm using an actual NES brand controller, then it's recognizing the controller as a SNES.
What i'm working on is a robot tank with camera and microphone, the camera will be mounted to a pan/tilt servo and i want to controll it with a wireless NES controller. So when i push UP both motors will go forward, when i push left the right motor will forward and the left will go backwards . . .
Thanks for helping
Daniel Mueth
Thanks for helping
Daniel Mueth
Daniel
"SNES"
then
"65535 1111111111111111"
and when i push a button the screen flashes like it refreshes but the text on the screen doesn't change.
again thank you
did you post the NES only version?
Post Edited (samsn4) : 11/10/2006 7:47:51 PM GMT
Daniel
