Convert ASCII String into Integer — Parallax Forums
SailerManSailerMan Posts: 337
edited 2006-11-10 19:05 in Propeller 1
I am using a Maxbotic Sonar the I have Choices of Output Serial, PWM or Analog. I used the PWM and now I'm attemping serial.
The data is Sent "R065\r"· 065 is the range in Inches.
I am reading the 065 into a short array and then Adding the Elements as so..
Repeat Index From 0 to 2
·· R[noparse][[/noparse]Index]=Serial.RX-48··· '<
FORGOT TO SUBTRACT 48
Range:=R[noparse][[/noparse]0]*100+R[noparse][[/noparse]1]*10+R[noparse][[/noparse]2]
It works but I'm wondering if there Is·a better way to handle this?
Eric
Post Edited (SailerMan) : 11/10/2006 5:19:39 PM GMT
    edited 2006-11-10 16:28
    If I understand your serial data, what you've posted can't work because the bytes are ASCII characters, not binary digits and you have to compensate for the extra $30 ("0") value. If you know you're going to receive a digit string terminated by a return, you can convert on the fly:
    Range := 0
    repeat until (d := Serial.RX) == $0D
      Range := Range * 10 + (d - "0")
  • SailerManSailerMan Posts: 337
    edited 2006-11-10 17:18
    Sorry for not being clear..You are totally correct in my code above.
    This is closer to my actual code
    If Serial.RX=="R"
       Repeat Index from 0 to 2
    Range:= R[noparse][[/noparse]0]*100+R*10+R
    I like your approach much better plus it helps me think outside of my little obscure box.
    If I understand your code it looks like a SHL·for Decimal.. Sheesh why didn't I think of that... smile.gif
    Thanks for your help,
    Eric
    Post Edited (SailerMan) : 11/10/2006 5:26:40 PM GMT
    Yeah, the same logic works for any base (binary, hexadecimal, etc.)
