Breadboard current and voltage limit
Hello,
I am trying to hookup·6 solenoids (maximum 2 activated at any moment)·to Stamp though MOSFET circuit, I have not worked much with breadboard in the past, can they handle 24 V DC and 6 Amp current ??? I am not sure how I can find current and voltage rating of breadboards ??
Thanks for help.
Happy Dude
Thanks for help.
Happy Dude
http://www.circuitspecialists.com·(Great boards, questionable service.)
·Sorry, no help.
·Tommy
(Frequently heard from other's)
Tommy, I know it wasn't designed to·x, but can you make it·do x·anyway?
Think outside the BOX!
Not being rude Metron9, but the "Let's see if it fries" approach is not the best way to offer advice to a new comer seeking advice.
Look at it this way: What if the rating on the breadboard is 4A. Then a run with 6A happens to hold up to the touch and smell test, in the short term. After multiple iterations of various tests, everything tastes alright. Just when you get confidence that all is ok, you decide to leave your project running for what ever reason while you go into the kitchen and cook dinner, hungry from all that hard scientific type work. After a series of over current experiments, the properties of the metals have changed. (Breakdown sometimes occurs over time, but when its time, you might not be in front of it when it happens). "Thermal runaway" sets in and we can hope that only the bench top and some components get cooked in the process.
Thermal Runaway: Component starts to heat, causing excessive heat, causing a decrease in resistance, causing an increase in current, causing excessive heat, causing a decrease in resistance, causing an increase in current... you get the picture.
Someone is bound to have the answer, I'd be patient. "The guy" at Circuit Specialist who knows, should be back to work soon.·He can't be the only one on this planet who knows the electrical characteristics of the ever elusive North American brown spotted breadboard.·
Post Edited (Tommy Bot) : 11/8/2006 8:20:23 PM GMT
Yes I do, but in this case lowering the resistance will cool the board. If my assumption is correct you are talking about running voltage in a metal strip at one end and out the metal strip at the other end. The metal strip is 1/2 inch long on the typical breadboard as I assume you are not powering the rails with the load. In any case my original post should have said if it gets warm, then NO as well as hot and melt but that's why I said to watch and measure while you do it.
I would go further and say if it stays cool, bring the amps up to 12 amps. If it stays cool then you have a 2 to 1 safety margin.
Yes, I don't recommend melting plastic, the smoke is very toxic from most plastics.
I only thought you were breadboarding it not using it for production or long term use. That kind of current even if the breadboard could take it would be unwise as a loose connection could very well short. A fuse would be highly recommended for long term use as well as breadboarding in case the teapot boils over and you decide to have some toast.
Re-read the post(s).
I'll leave the rest of it alone, I know you're only trying to help. Your comment "That kind of current even if the breadboard could take it would be unwise..." shows that you have a partial grasp on where I'm coming from.
Tommy
- Rick
Better run your control wires from the breadboard to the relays soldered to a circuit board.
Thanks, I think I·will go with PCB solution for large amp circuit, hope I will not fry some thing ...
The connections are merely by friction and the conductors are 20 gauge wire or smaller. Therein lie your limits - high resistance connection, small surface contact.
Regarding voltage, it is generally accepted that 48volts and less presents a signicantly smaller fire harzard from sparking and wires overheating. So I would add 100% safety margin and say not more than 24volts for generic breadboards.
Testing comes in two modes -- Destructive and Non-destructive.
Destructive testing implies that one must always provide a safety proceedure with the test.
And even with non-destrcutive testing, safety can be a significant issue as failure may occur anyway.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
