Silent Audio Switching
To swicth a a Hi-z input and retain straight wire I am going to use relays. I want to add a shunt to ground to trip prior to the relay to avoid contact noise. Ideally, a ramping up or down would be best to fade the audio over a few ms. (RC and FET?) Any suggestions on a circuit to accomplish this idea? The processor will either be a Propeller or SX. The shunt would have to be very quite also. It would short the input to GND prior to connecting/disconnecting the relay.
Thanks for any ideas.
·· If you have fairly clean Relay contacts and your audio inputs are capacitively coupled you shouldn’t really have a lot of noise.· There are Integrated Circuits for switching audio as well.· Many have an I2C or SPI bus control, while some are parallel.
Chris Savage
Parallax Tech Support
Rick
