Using an objects constants — Parallax Forums
Steve Hicks (N5AC)Steve Hicks (N5AC) Posts: 20
edited 2006-11-05 19:50 in Propeller 1
I have an object that has some parameters that are "mode switches."· The value being passed in determines how the function will handle the other data.· I would like to define these as constants in a CON section such as
CON
· rateSlow = 4800
· rateFast = 9600
OBJ
· myObject: "myObject"
PUB Start
· myObject.Init (rateSlow)
My problem is that I seem to have to define these (constants) in both the object used as well as the program using the object.· Is this correct?· Is there an elegant way to do this other than extracting the constant section out of the object in use and pasting it in the consumer of the object?
Steve
Steve, N5AC
    edited 2006-11-05 19:45
    Steve,
    You can use the notation Object#rateSlow to do just what you're after. (See page 141 of the manual.)
  • Steve Hicks (N5AC)Steve Hicks (N5AC) Posts: 20
    Thanks, Phil!· Just what I was looking for.· I always read the manual for a new part cover to cover which I did this time, but I must have forgotten by the time I got to the end!
    Steve
    Steve, N5AC
