Check out my Linux port of JavelinDirect
avelin Folks,
I had some time between jobs, so I tried porting Parralax's JavelinDirect program to Linux, replacing the ComDrv32.pas source with a POSIX-compliant ComDrv32.cpp, so downloading to Javelin outside of Wine would be possible.
Currently, the download portion is not working. I suspect it has to do with my configuring the baud rate at 19200 instead of 28800, which doesn't seem to be available in Linux.
The source and some comments about how far I got is available at http://www.pwan.org/JavelinDirect/index.html
Let me know if you see anything that's wrong with the port configuration, or any other bugs I may have introduced with the port.
Sorry in advance if there's already a Linux port available, but I couldn't find it if there is one.
- jude
- jude
You need to have the 28800 baud though.
So if anyone knows how to set 28800 baud under linux, let us know.
regards peter
Post Edited (para6654) : 11/4/2006 5:01:12 PM GMT
However, if I saved the file to disk first, and then opened with WinZip, it worked OK.
I was using an evaluation copy of WinZip version 10.0
I tried to force the port to 28800 using the command 'setserial /dev/ttyS0 spd_cust baud_base 28800 divisor 1'.
I also tried using a base baud rate of 115200 and a divisor of 4, but without any luck.
I was basing this on section 14.3 of the Linux Modem HOWTO
(http://www.linux.com/howtos/Modem-HOWTO-14.shtml)
I also tried using stty, but for some reason I can't set the baud rate past 19200 with stty.
My setserial / stty output is below, if anyone's interested.
- jude
pwan /home/pwan/ >stty -F /dev/ttyS0 -a
speed 19200 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>; eol2 = <undef>;
swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V;
flush = ^O; min = 0; time = 10;
-parenb -parodd cs8 hupcl -cstopb cread clocal -crtscts
ignbrk -brkint ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff -iuclc -ixany
-imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon -iexten -echo -echoe -echok -echonl -noflsh -xcase -tostop -echoprt -echoctl
-echoke
pwan /home/pwan/ >setserial /dev/ttyS0 -G -a
/dev/ttyS0, Line 0, UART: 16550A, Port: 0x03f8, IRQ: 4
Baud_base: 28800, close_delay: 50, divisor: 1
closing_wait: none
Flags: spd_cust skip_test callout_noh
pwan /home/pwan/ >stty -F /dev/ttyS0 38400
stty: /dev/ttyS0: unable to perform all requested operations
http://sourceforge.net/projects/serial/
It is a standalone package for 8250/16550 compatible chips.
regards peter
If not, I'd be glad to help as I have made a good deal of progress
communicating with the Javelin using a Java port of JavelinDirect
on Linux.
please post it.
regards peter
I actually just performed my first successful upload to a javelin last night.
- Andrew
Jonathan
I have just published release 0.1.0-RC1 of JavelinTools for Linux. Check out: http://forums.parallax.com/forums/default.aspx?f=8&m=170317 for details.
- Andrew
