Propeller SID emulation???
cbmeeks
With the exciting audio demos coming from Chip recently, anyone think a SID (Sound Interface Device) could be emulated on the Prop? Or maybe just a generic synthesizer with ADSR abilities, white noise, etc?
I'm sure a tone generator wouldn't be too hard. I want to see a Propeller Demo Scene! hahaha
cbmeeks
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
cbmeeks
Coders' Hangout
METROID?
Metroid Classic
You could do a SID in one COG, I think, no problem.
Chip Gracey
Well, *I* couldn't but someone with your advance knowledge, experience, wisdom and good looks could definately do it. (ok, I am brown-nosing here) hahahaha
Coders' Hangout
METROID?
Metroid Classic
However, it was the quirks, bugs and analogue aspects of the chip (it was actually an analogue-digital hybrid) that made it special, and most of the sounds we'd recognise from the good old C64 days were more the result of good 6510 programming pushing the chip to its limits than the chip's actual capabilities. It was a combination of hardware limitations and the very real passion that the industry/scene had back in the early-mid 80s that gave rise to the amazing level of creativity we saw from the greats like Rob Hubbard & Martin Galway. Truly the greatest time there has ever been for computer music, and sadly, something I don't think we'll ever see again.
If I had a little more time, and fewer items already on my Propeller to-do list, I'd have a go myself.
ANYWAY, seems like if you look at the pure SID technology, and if memory serves me, you are looking at ADSR applied to square, triangle, sawtooth and white noise. Was there a sine wave?? Take that and multiply by 3. I wouldn't really be interested in 100% emulation (like the analog in/pots/etc).
Ultimately the coolest version could convert SID music either on the fly or with a converter so that we could enjoy the thousands of SID tunes out there. Run on two cogs and you have SID+stereo. With maybe 1-3 cogs for sampled sounds? That would really be a great 8-bit retro computer sound system.
cbmeeks
Coders' Hangout
METROID?
Metroid Classic
I'd love to have a portable/pocket device (rather than a PDA) that I could play C64 tunes on. I really am such a nerd.
I started working on the SID engine already for a C64 project.
The only thing is it doesn't support is Ring-Modulation and the Filter at the moment.
Cbmeeks you seems to be showing a lot of interest in sound systhesis at the moment.
Maybe I'll send you some of my code to play around with. I've been sort of interested in writing a sound-chip that uses all of the propeller's power. I've already gotten 7 monophonic channels out of a single cog with mixing and volume control! So picture what 8 COGs could do?
(btw) talking about the demoscene, I've writen 9 songs already that play on the propeller using my sound firmware.
I'm hoping to see a Demoscene move to the propeller as well with the release of the Hydra.
--Andrew Arsenault.
My homebrew is going to be controlled by a 6502. Right now I'm thinking of three props which some may see as overkill. One for audio, one for video, and one for I/O, etc.
Coders' Hangout
METROID?
Metroid Classic
Coders' Hangout
METROID?
Metroid Classic
Until then you can listen to this song I wrote under (HSS).
Recorded right from the propeller demoboard output.
www.andrewarsenault.com/hss/Ym2413a_Sine.mp3
It's amazing what you've done with only two cogs.
Coders' Hangout
METROID?
Metroid Classic
The above song still only uses 4 out of the 7 channels available. In (HSS) the 3 last channels, WaveTable 5 and 6 along with ADPCM are saved for sound FX and samples. This way the programmer can play sounds and wave samples without cutting into the music or stealing channels from eachother.
