Sx Key Dead??
Cant get any program to work on Pro development board brand new. I can load program into sx or at least thats what it says. but when the debug screen is open you cant use the run, walk or step buttons, and it never says idle on the status·at the top of the debug box is allways running.Is there a way to check to see if the SX-key is sending the code to the SX chip, I have a parallax USB oscilloscope. Have just about run out of solutions to fix this problem, have run all on two different computers used two diferent cables and both the SX28AC chips that were sent. e-mailed parralax support yesterday·and got no awnser·as of today·, could be·swamped. Any Help Thanks David·
Greetings from Germany,
G
