Laser stuff for those interested
I have recently discovered that Jameco.com has a laser diode with about a 100 yard range that is Class IIIa (eye safe). The diode is 14.95 and the compatable driver is 7.95 - total cost 23 bucks.
The link for the laser diode
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=182932
The link for the driver
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=161736
I figured these would work good for a range finder but·haven't found a light sensor to handle the return signal yet. If I do it will get posted.
If anyone knows where to get a sensor that can detect the return light please·post the link.
·· A Laser Range Finder would require you to modulate the laser signal and be able to detect the modulation within a very short amount of time, so you would need a very fast reacting detector as well as circuitry which can operate at those speeds (just under speed of light).
Chris Savage
Parallax Tech Support
So a sx at 50mhz light travels about 20 feet per clock cycle
you have 5 clock cycles to measure 100 feet
not gonna happen
But I have always wanted to make a laser dector to detect breaking the beam , an invisible fence system for my back yard.
Think outside the BOX!
Trig based range finder-- Maybe
Just a thought
NerdMaster
For
Life
In other words, send a pulse every 10 or 20 ms and then calculate the time diference between recieved signals to get your distance. Doesn't need to be faster then that, just needs to be able to know when tripped. As long as the recieving end is capable of tracking at 10 to 20 ms it will work if the measurement is between the recieved times.
http://www.eodevices.com/main_eho_1_frameset.htm
It refers to the Basic stamp.
What kind of resolution do you want? If your pulse is long, remember that you can't start "listening" for you pulse until you've finished transmitting. You're basically blind for this time.
Anyhow, the idea is simple....but find the parts. They tend to get $$ pretty quick. Have you seen a laser range finder for less than a couple hundred $? (not up here in Canada)
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Link: http://www.parallax.com/images/customer_apps/willp/Robot%20Wall%20Sensors.pdf
Harrison
There are non-time of flight means for doing laser ranging finding, but are complex and beyond the direct capabilities of a Stamp for different reasons.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 11/1/2006 1:59:08 AM GMT
Unless there is someone out there who makes a much cheaper laser range finder I am going to have to build my own, and so far I can get a driver and 650 nM Class IIIa laser combination for under $25.
I just need to find a way to read the return so there is useful information provided. Mouser.com has optics but so far there isn't anything discovered on a way to capture a return signal.
I don't really care if the outgoing pulse takes 1/20th of a second pause or even more. The stuff used doesn't have to be·top·notch, just useable at or below human reaction speed.
Here is a link you should find interesting and informative: http://www.philohome.com/sensors/lasersensor.htm
(edit: dagnabit·I just realized the above link is useless, it is like the default IR detector configuration, it only provides an "Object/No Object" output only for·much further distances. There was an article posted that was true rangefinding, I'll go look for it)
The important measure isn't the length of time the laser is on for, its how long it takes to hit the target and bounce back. To achieve resolution of 1 foot, you need to be measuring the round trip with a·500 MHz detection unit. A·250 MHz detection unit gives a resolution of 2 feet (ie is it 2,4,6,8,... feet away). And a 100 MHz detection unit can only measure in 5ft increments, and it only gets worse from there. Measuring the signal directly from stamp speeds, and your talking about 50s of miles (is it 50, 100, 150, ... miles away, not very practical).
Paul Baker
Post Edited (Paul Baker (Parallax)) : 11/1/2006 5:03:41 AM GMT
Its the article "Measuring the speed of light".
Paul Baker
kelvin
p.s. Any laser can still hurt the eyes on continuous exposure.
Paul Baker
I was going to mention the Bushmills laser ranging binoculars as cheap, but at over $500 you've got them beat.
Interested to see a hacked version for sure!
Steve
kelvin
Truly Understand the Fundamentals and the Path will be so much easier...
Mouser, Jameco and Sharp Microelectronics all have Lasers and/or drivers but so far no one has a reciever.
kelvin
www.eodevices.com/main_eodmain_frameset.htm
You may best be served by using the trigonometric method of laser rangefinding. It is a much simpler method of of performing distance finding. This is where a laser is placed in line and a slight angle with a linear array sensor (TAOS makes such sensors). A lens is used and placed so the linear sensor is at its focal length, the laser spot will be reflected back onto a different spot on the sensor. Here's a crude diagram of the setup:
Paul Baker
Remove the .txt file extension to view the video.
His diagram talks about using the light to frequency meter (he drafted it for use with Parallax parts, but the TSL3301 will provide a higher resolution result (which is a 102 pixel 8 bit intensity serial output linear sensor)).
Paul Baker
Post Edited (Paul Baker (Parallax)) : 11/2/2006 11:51:46 PM GMT
Paul Baker
I am aware that judging distance using your eyes is performed similarly except it takes two eyes for the brain to make the distance calculation. I know because I am almost blind in one eye. The question then is, if my brain can not judge distance using only one eye how can a micro controller? I see the dot moves across the page given the distance variation but with two eyes the distance is calculated from the difference between the two images on the retinas. I would think you would need two laser spots with a known distance between them to calculate distance in this manner.
Remember I have no clue about this and I am just trying to fit the two seemingly opposing ideas into a logical container.
PAR
You are correct, without both eyes your depth perception is severely impacted.
With binocular vision, humans measure depth by comparing the two slightly different
2D images from each eye.· If you think about it this is a remarkable ability, the
brain is capable of taking two images, filtering out the noise, and producing a
smooth rendition of the 3D world around us.
...Back to the laser distance question.· Its actually very much the same thing.
Your eyes work by sending the signals to your brain and then your brain takes this
information, converges the signals and interprets the difference.
Suppose you had one eye that was "fixed".· You could see just fine, but you couldn't
move it left, right, up, or down without moving your entire head around... it would
probably be a pain in the &^*&$! but eventually you would learn to adapt, because
your brain would "know where it is" relative to the position of your other eye.· Over
time your brain would adapt and learn to filter out any noise and eventually provide
a smooth rendition.· Now consider the laser as the "fixed" eye.· We know where the
laser is mathematically because of the angle the laser has been set to in our design
and the distance of the laser relative to the sensor in our design.· The "sensor" that
is detecting the position of the laser point would essentially be your "other" eye.
Now by reading the sensor we can calculate the depth based on the convergence of the
known angle of the laser, the distance from the laser to the sensor, and the position
of the laser point that the sensor is providing.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 11/4/2006 6:46:13 AM GMT
Sure, both systems have a sort of "binocularity", and both "calculate" distance to target. So, in that sense, they're "much the same thing".
But, people with one-eyed vision can move there heads to provide an alternative sort of binocular cues, and both two-eyed and one-eyed persons' brains·use·much more and different information than simple trigonometry to estimate depth and relative and absolute·distance.
It is in this more detailed sense (of human experiences,·perceptions and brainpower) that I suggest that the two systems of estimating distances are quite dissimilar.
PAR
Agreed, however people with one-eyed vision moving there heads to provide an alternative monocular view, still provide the brain with two images to compare. I do not doubt that there
are many more things at work than simple trigonometry when it comes to how we interpret distance. What I was trying to give was an explanation that was more along the line of apples to apples
in reference to the trig-laser method of determining distance.
Beau Schwabe
IC Layout Engineer
·· The laser is firing its beam straight out and it is being reflected back onto a linear optical array.· Depending on the distance from the object the laser beam will be striking a different section of the array and that is how the distance is determined.· So basically where the array is, the beam will hit a different part of it based on the distance from the object.· Take care.
Chris Savage
It uses the parallax method, but I was disapointed to find that it only used an IR LED, not a laser.
I am currently working on a method for a laser scanner to detect reflective targets covered with a barcode. So, I am looking for similar sensors, but don't need the linear array of sensors.
Joe Dunfee
