Basic Stamp 1 Project Board problems
Hello, recently I bought a Basic Stamp 1 Project Board. I have been testing it and experimenting with it a lot.
The problem is that it shuts down and I can't start it so easily after that. I wrote a program than receives signals from a remote-control and I am using it for turning lights on and off. But when I leave the Basic Stamp running the program over night it shuts down or crashes or something. The red light that indicates that it is on doesn't lit either.
Now I wonder why The Basic Stamp 1 shuts down/crashes?
(Sorry for my bad English)
Post Edited (Exige) : 10/30/2006 8:11:08 PM GMT
Please , try to give us more information. Try posting a sample of your conections and your code. will be much easier to help.
Amaral.
The program is working very good, but when I leave the Basic Stamp 1 running it over a night the red "Power" led doesn't lit. I don't think my connections is the problem just because i works fine for many hours.
That must be the problem? The basic stamp 1 project board technical specifications say it should draw about 5 mA in sleep mode and 7 mA running. Is the board defect?
·· Where (at what point) are you measuring the current, before or after the voltage regulator?· Or are you feeding voltage into VIN?· I take it this program downloads okay?
Chris Savage
Parallax Tech Support
Vin is before the regulator and Vdd is after?
Chris Savage
My power source is a 9-volt battery. I don't think the regulator should take so much current...
Chris Savage
Chris Savage
Chris Savage
I wish my multimeter was faulty but sinse I have two different multimeters there is little chance that both would display the wrong current. For example one of my multimeters is displaying 0.062A.
So now I have two questions:
How could the current draw be about 10 times more on a 9 volt battery? (The 9 volt battery is actually rechargeable, if that makes any difference.)
And why can’t (my) basic stamp 1 project board be running more than a few hours before it stops/shuts down/crashes?
I am very grateful to any answers.
·· You listed a specific program that this is happening.· If you write a simple program to blink an LED does the Project Board stop running then?· Try a simple loop that runs continuously and blinks and LED and see what happens.·
Chris Savage
But I don't see why my program that remote controls leds stops running after some time.
Chris Savage
Thank you Chris for helping me [noparse]:)[/noparse]
Chris Savage
