how do you keep a servo powered so it doesnt relax during a routine
High everyone,
im working on a project that requires a servo to hold up an object. the problem is that everytime the servo moves it "relaxes" under the weight.
Is there some tupe of command or routine that will keep itsteady or "powered" while the other programs run?
Thanks for any and all input,
Charles Cline
Charles Cline
· Servos require that the position signal be repeated about every 20 milliseconds... put your "pulsout" routine in a loop
sorry new to this
Main:
' Do lots of stuff
GOSUB SetServo
PAUSE 20
GOTO MAIN
SetServo:
PULSOUT Serv1Pin, 500 + 2 * ServoPos1
' Note: A servo goes from 1 mSec to 2 mSec.
' PULSOUT on the BS2 uses 2 uSec 'ticks'.
' So, the PULSOUT value should go from 500 to 750 to 1000.
' So, you can do this with one byte with 500 + 2 * <ByteValue>
' Where <ByteValue> should range from 0 to 125 to 250
' Add addional 'servo settings' here
RETURN
The way that most deal with this problem is to offload the "refreshing" to a servo controller board. I can highly recommend the Parallax Servo Controller (PSC). You just tell it, using SEROUT, what position you want your servo to go to, and it will hold it there while your Stamp does other things. And on top of that, you can control up to 8 servos with one board, addressing each·servo individually...all for a very good price and with the greatest support out there (or in here).
Ther is more to be said, but it is covered in the product description and elsewhere on these fora.
Truly Understand the Fundamentals and the Path will be so much easier...
Post Edited (Tom Walker) : 10/25/2006 5:06:07 PM GMT
I'm doing a similar servo control project (self leveling platform using mez-whatever 2125) and get some pretty jittery results. I notice it's better (less jitter) when shortening the "PAUSE 20" to "PAUSE 5". I'm assuming that the rest of the code takes the other 15... Any other tips or tricks for minimizing servo jitter and optimizing timing?
Mark
·· It is entirely possible to write your other routines to handle refreshing the servo while still handling other functions.· Almost everything runs in some kind of loop, so it would make sense to handle it there.· How would be specific to your code.
Mark,
·· Servos require refreshing every 20 – 50 mS.· If you’re doing it too often it will usually result in jitter as you’re over-driving the servo’s internal pulse circuitry.· Assuming the code takes 15 mS to run may be incorrect.· In fact you would need to be doing a lot of stuff to take that long.· If you have a scope you can measure the outgoing pulse to see how often it’s happening.· My guess is too often.· On the other hand you could just set the PAUSE back to 20 and see how it works, then reduce it from there.· Take care.
Chris Savage
Parallax Tech Support
heres the camera code. this is the original not the changed one, but the servos run like this one, what i need to do is keep the servos refreshed inbetween movements. Could you show me how i can implement this, thanks so much,,
'{$STAMP BS2}
'{$PBASIC 2.5}
' CMUcam1 BoeBot AppMod 1.1
' Basic Stamp 2
' CMUcam1 jumpered for 9600 Baud
RcvData VAR Byte(10) ' Array
SaveColorData VAR Byte(6) ' Array
Result VAR Word
RCcalibrate VAR Word
N VAR Byte ' General purpose counter variable
LostTrack VAR Nib
Switch VAR Nib
Debounce VAR Nib
Function VAR Nib
Main:
' Pause for CMUcam1 startup
FOR N = 2 TO 5 ' Flash all LED's during pause
SHIFTOUT 4,8,MSBFIRST,[noparse][[/noparse]255]
PAUSE 400
SHIFTOUT 4,8,MSBFIRST,[noparse][[/noparse]0]
PAUSE 400
NEXT
' Calibrate the button RCtime value
HIGH 5
PAUSE 1 ' for 1 ms.
RCTIME 5, 1, RCcalibrate
FREQOUT 13, 400, 2500 ' Beep to indicate ready
ProgTop:
' Select function from push buttons
GOSUB GetButton
Debounce=Switch
GOSUB GetButton
' Get button press twice and compare if not the same repeat
IF Debounce <> Switch THEN ProgTop
IF Switch = 2 THEN ' If Go/Stop button pushed then beep
FREQOUT 13, 400, 2500 ' beep
ENDIF
BRANCH Switch, [noparse][[/noparse]ProgTop,Buttonselect,Execute]
Buttonselect:
Function = Function + 1
IF Function > 9 THEN
Function = 1
SHIFTOUT 4,8,LSBFIRST,
ENDIF
PAUSE 300
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]DCD(Function-1)]
GOTO ProgTop
Execute:
BRANCH Function, [noparse][[/noparse]ProgTop,Calibrate,SaveColor,TrackColor,Avoid,Adapt,FollowLine,Point,Color]
GOTO ProgTop
GetButton:
Switch=0
' Activate RCtime for two buttons
HIGH 5
PAUSE 50 ' for 1 ms.
RCTIME 5, 1, Result
IF Result>=RCcalibrate-200 THEN
Switch = 0 ' No button pressed
RETURN
ENDIF
IF Result>((RCcalibrate/4)*3)-500 THEN
Switch = 1 ' Select button pressed
RETURN
ENDIF
IF Result>(RCcalibrate/2)-500 THEN
Switch = 2 ' GO/Stop button pressed
RETURN
ENDIF
Switch = 3 ' Both buttons pressed at the same time
RETURN
' Track the color previously saved in EEPROM
TrackColor:
GOSUB ConfigureCMUcam
' Read EEPROM into SaveColorData array
READ 0, SaveColorData(0)
READ 1, SaveColorData(1)
READ 2, SaveColorData(2)
READ 3, SaveColorData(3)
READ 4, SaveColorData(4)
READ 5, SaveColorData(5)
' Set Track Color values from EEPROM
SEROUT 7,84,[noparse][[/noparse]"TC"]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(0)]
SEROUT 7,84,[noparse][[/noparse]" "]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(1)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(2)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(3)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(4)]
SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(5),CR]
PAUSE 200
TopTrack:
SHIFTOUT 4,8,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
GOSUB GetButton ' Check for stop button press
IF Switch = 2 THEN' Switch 2 is stop button
' Two beeps for Stop
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]DCD (Function-1)]
PAUSE 200
PAUSE 200
' Reset the green tracking LED
SEROUT 7, 84, [noparse][[/noparse]"L1 0",CR] ' Green LED off
PAUSE 100
SEROUT 7, 84, [noparse][[/noparse]"L1 2",CR] ' Green LED auto mode
PAUSE 100
GOTO ProgTop
ENDIF
' Send command - Track color (with no arguments) -
' will track last color grabbed by TW command
SEROUT 7, 84, [noparse][[/noparse]"TC",CR]
SERIN 9, 84, [noparse][[/noparse]STR RcvData\10]
PAUSE 100
' 45 is aprox H center, 70 is aprox V center
' Track and follow logic
IF Function = 3 THEN
IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft
IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight
IF RCVData(7) > 120 AND RcvData(9) > 25 THEN Bwd
IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd
ENDIF
' Move and avoid logic
IF Function = 4 THEN
IF RCVData(3) > 50 AND RcvData(9) > 20 THEN Fwd
IF RCVData(3) < 50 THEN BackUp
IF RcvData(9) <= 20 THEN BackUp
ENDIF
' Adaptive tracking logic
IF Function = 5 THEN
IF LostTrack > 6 THEN TW
LostTrack = LostTrack + 1
IF RcvData(9) > 25 THEN LostTrack = 0
ENDIF
' Line Following logic
IF Function = 6 THEN
IF RCVData(2) > 50 AND RcvData(9) > 5 THEN TurnLeft ' 45
IF RCVData(2) < 40 AND RcvData(9) > 5 THEN TurnRight ' 45
IF RCVData(2) >= 40 AND RCVData(2) =< 50 AND RcvData(9) > 5 THEN Fwd
ENDIF
' Finger point logic
IF Function = 7 THEN
IF RCVData(2) > 60 AND RcvData(9) > 25 THEN RotateRight ' Centroid X
IF RCVData(2) < 30 AND RcvData(9) > 25 THEN RotateLeft ' Centroid X
IF RCVData(3) > 30 AND RcvData(9) > 15 THEN Bwd ' Centroid Y
ENDIF
' Color logic
IF Function = 8 THEN
SEROUT 7, 84, [noparse][[/noparse]"TC 30 240 16 30 16 30",CR] ' Red
IF RcvData(9) > 20 THEN
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]195] ' All Red LED's on
PAUSE 500
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]0] ' All LED's off
ENDIF
SEROUT 7, 84, [noparse][[/noparse]"TC 16 40 30 240 90 170",CR] ' Green
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]24] ' All Green LED's on
PAUSE 500
ENDIF
SEROUT 7, 84, [noparse][[/noparse]"TC 200 240 200 240 16 50",CR] ' Yellow
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]36] ' All Yellow LED's on
PAUSE 500
ENDIF
ENDIF
' Flash LED's to show bottom of tracking loop
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]129] ' 100000001
GOTO TopTrack
' Calibrate CMUcam1 for lighting conditions
Calibrate:
' Reset CMUcam1
SEROUT 7, 84, [noparse][[/noparse]"RS",CR]
PAUSE 200
' Turn on auto adjust
SEROUT 7, 84, [noparse][[/noparse]"CR 18 44",CR]
PAUSE 100
' Delay loop for CMUcam1 to auto adjust to lighting conditions
FOR N = 2 TO 255
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]DCD (N)]
GOSUB GetButton ' Check for stop button pressed
IF Switch = 2 THEN EXIT ' Switch 2 is stop button
NEXT
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]0] ' 000000000
' Turn off auto adjust
SEROUT 7, 84, [noparse][[/noparse]"CR 18 44 19 32",CR]
PAUSE 100
SHIFTOUT 4,8,LSBFIRST, ' 100000000
PAUSE 300
GOTO ProgTop
SaveColor:
' sample and save color
SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]
PAUSE 100
' Set a small window in center
SEROUT 7,84,[noparse][[/noparse]"SW 30 54 50 90",CR]
PAUSE 100
' Set raw mode 3
SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]
PAUSE 100
'set minimun and maximun values
SaveColorData(0)=16
SaveColorData(1)=240
SaveColorData(2)=16
SaveColorData(3)=240
SaveColorData(4)=16
SaveColorData(5)=240
' Get Mean
SEROUT 7,84,[noparse][[/noparse]"GM",CR]
SERIN 9,84, [noparse][[/noparse]STR rcvdata\8]
PAUSE 200
IF rcvdata(2)<=46 THEN gm1
SaveColorData(0)=(rcvdata(2)-30)
gm1:
IF rcvdata(3)<=46 THEN gm2
SaveColorData(2)=(rcvdata(3)-30)
gm2:
IF rcvdata(4)<=46 THEN gm3
saveColorData(4)=(rcvdata(4)-30)
gm3:
IF rcvdata(2)>210 THEN gm4
saveColorData(1)=(rcvdata(2)+30)
gm4:
IF rcvdata(3)>240 THEN gm5
saveColorData(3)=(rcvdata(3)+30)
gm5:
IF rcvdata(4)>240 THEN gm6
saveColorData(5)=(rcvdata(4)+30)
gm6:
' Set raw mode to 0
SEROUT 7,84,[noparse][[/noparse]"RM 0",CR]
PAUSE 100
' Return window to full size
SEROUT 7,84,[noparse][[/noparse]"SW",CR]
' Write color tracking range values to end of EEPROM
WRITE 0,saveColorData(0)
WRITE 1,saveColorData(1)
WRITE 2,saveColorData(2)
WRITE 3,saveColorData(3)
WRITE 4,saveColorData(4)
WRITE 5,saveColorData(5)
' Two beeps
PAUSE 400
PAUSE 400
GOTO ProgTop
Avoid:
SEROUT 7,84,[noparse][[/noparse]"TW",CR]
PAUSE 1000 ' Wait 1 second for TW
GOTO TopTrack
Adapt:
TW:
SHIFTOUT 4,8,MSBFIRST,[noparse][[/noparse]255] ' All LED's on
FREQOUT 13, 150, 2500 ' Beep
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"TW",CR] ' Send Track Window command
PAUSE 1000 ' Wait 1 second for TW to complete
LostTrack = 0 ' Reset LostTrack counter
GOTO TopTrack
FollowLine:
SEROUT 7,84,[noparse][[/noparse]"TC 16 50 16 50 16 50",CR]' Black line color
PAUSE 100
GOTO Toptrack
Point:
SEROUT 7,84,[noparse][[/noparse]"TC 200 240 180 240 50 100",CR] ' Skin color
PAUSE 100
GOTO Toptrack
Color:
GOTO Toptrack
ConfigureCMUcam:
SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]' Poll Mode
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]' Raw Mode
PAUSE 100
SEROUT 7,84,[noparse][[/noparse]"CR 32 8",CR]' White Balance smart mode
PAUSE 100
RETURN
BackUp:
' backup
FOR n = 1 TO 15
PULSOUT 14,1000 ' **
PAUSE 15
NEXT
PAUSE 200
' rotate about 90 degrees
SHIFTOUT 4,8,LSBFIRST,[noparse][[/noparse]32]
FOR n = 1 TO 100
NEXT
GOTO TopTrack
RotateLeft:
FOR n = 1 TO 10
PULSOUT 15,500 ' **
NEXT
GOTO TopTrack
RotateRight:
FOR n = 1 TO 10
PULSOUT 15,1000 ' **
NEXT
GOTO TopTrack
TurnLeft:
FOR n = 1 TO 40
PULSOUT 15,750 ' **
NEXT
GOTO TopTrack
TurnRight:
FOR n = 1 TO 40
NEXT
GOTO TopTrack
Bwd:
FOR n = 1 TO 10
PAUSE 15
NEXT
GOTO TopTrack
Fwd:
FOR n = 1 TO 10
PULSOUT 14,500 ' **
PAUSE 15
NEXT
GOTO TopTrack
·· Attaching the code would help, since it is very difficult to read the way it is shown…All the formatting is messed up as well.
Chris Savage
' backup
FOR n = 1 TO 15
PAUSE 15
NEXT
PAUSE 200
FOR n = 1 TO 100
NEXT
GOTO TopTrack
RotateLeft:
FOR n = 1 TO 10
PULSOUT 15,500 ' **
NEXT
GOTO TopTrack
RotateRight:
FOR n = 1 TO 10
NEXT
GOTO TopTrack
TurnLeft:
FOR n = 1 TO 40
PULSOUT 15,750 ' **
NEXT
GOTO TopTrack
TurnRight:
FOR n = 1 TO 40
NEXT
GOTO TopTrack
Bwd:
FOR n = 1 TO 10
PAUSE 15
NEXT
GOTO TopTrack
Fwd:
FOR n = 1 TO 10
PULSOUT 14,500 ' **
PAUSE 15
NEXT
GOTO TopTrackd got messed up let me try that again
it is the 8 function demo from the camera i bought from parallax,
the backword and forword commands are now elevation,
its only pin 14 elevation
pin 15 rotation,,
i placed the board and camera on a rotating tripod and am using a servo to elevate the board and camera
