question about System.out.println
The following code does not work:
int value;
System.out.println ("The value is ", value);
However, it works if I break into:
int value;
System.out.println ("The value is ");
System.out.println (value);
1.· println can only output 1 thing at a time?
2.· where is this stated in the Javelin manual?· (I don't believe this is a restriction of Java).
Thanks.
int value;
int value;
Thanks.
Open help, packages, java.lang
From Class summary, select System, then click out, then click PrintStream.
That lists all methods for System.out
Indeed, all these methods take only 1 argument.
regards peter
System.out.println ("The value is " + value); //I'm not sure if you need to cast the value to (int)
However that will use a lot more memory than if you put them on two lines as you have it now, because it will create a new string if you do it the one line way.
