Does Wakeup reset RAM values ?
When I exit from SLEEP mode, RAM variables are preserved ?
Does Wakeup have the same effect as a RESET ?
http://www.parallax.com/dl/appnt/sx/An18Reset.pdf
Bean
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
I understand by this document that on a SX28AC wakeup process takes about 18ms and SRAM is preserved.
I think this may work well for my project. Thank you!
but in some cases it may change states on you. Notice the direction registers on wakeup, and then watch your pin data
closely. In one of my programs/hardware I found I needed to shadow the pin data before going into a sleep, and reset
that data on wakeup. This 'feature' almost cost a bunch of time and $$$. I've seen reference to this before, but couldn't
seem to find it again.
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
