BS2p24/BOE and LCD Terminal AppMod
I'm having a problem using the LCD Terminal Appmod with a BS2p24. Even the LCD_AppMod_Demo.BS2 found on the LCD Terminal Appmod page is not functioning properly. However, if I use the BS2 the LCD functions as expected. BTY not functioning means Blackish squares where chars should be. Yes, I tried adjusting the contrast POT
Test code (from PBASIC help)
' {$STAMP BS2p}
' {$PBASIC 2.5}
Init_LCD:
PAUSE 1000 ' allow LCD to power-up
LCDCMD 1, 48 ' Send wake-up sequence (3x)
PAUSE 5
LCDCMD 1, 48
PAUSE 1
LCDCMD 1, 48
PAUSE 1
LCDCMD 1, 32 ' Set data bus to 4-bit mode
LCDCMD 1, 40 ' Set 2-line mode with 5x8 font
LCDCMD 1, 8 ' Turn display off
LCDCMD 1, 12 ' Turn display on without cursor
LCDCMD 1, 6 ' Auto-increment cursor
LCDCMD 1, 1 ' Clear the display
Main:
GOSUB Init_LCD - Oops - should have removed this line
LCDOUT 1, 1, [noparse][[/noparse]"Hello World!"]
STOP
Thanks a bunch
Post Edited (Mike Gebhard) : 10/26/2006 11:53:26 PM GMT
' {$STAMP BS2p}
' {$PBASIC 2.5}
Init_LCD:
PAUSE 5
LCDCMD 1, 48
PAUSE 1
LCDCMD 1, 48
PAUSE 1
Main:
STOP
Thanks a bunch
The code is a little mixed up - no return from the Subroutine Init_LCD - and the main code was after the sub so as you presented it, it would go through the Init_LCD code, fall into Main when the Init_LCD is called again (without a return), etc.
A couple of other observations,
- there are distinctly different commands when using the BS2 vs BS2P - the code you used and the code below are for BS2P
- LCDCMD for BS2P family
- PULSOUT for BS2
- the statement #DEFINE _LcdReady = ($STAMP = BS2P) OR ($STAMP = BS2PE) is key as it determines which to use based on the $STAMP definition
- you may need to allow for Proc speed vs. LCD speed via PAUSESes (I'm not sure as I have been working exclusively with Serial LCD's.
Try this (on your BS2P:
' {$STAMP BS2P} ' {$PBASIC 2.5} #SELECT $STAMP #CASE BS2, BS2E LCD_Pause CON 10 #CASE BS2SX, BS2P, BS2PE LCD_Pause CON 20 #ENDSELECT #DEFINE _LcdReady = ($STAMP = BS2P) OR ($STAMP = BS2PE) Main: #IF NOT _LCDReady #THEN DEBUG CR, "Commands for BS2 not implemented - please use BS2P", CR, CR END #ENDIF GOSUB Init_LCD LCDOUT 1, 1, [noparse][[/noparse]"Hello World!"] STOP Init_LCD: PAUSE 1000 ' allow LCD to power-up LCDCMD 1, 48 ' Send wake-up sequence (3x) PAUSE LCD_Pause LCDCMD 1, 48 PAUSE LCD_Pause LCDCMD 1, 48 PAUSE LCD_Pause LCDCMD 1, 32 ' Set data bus to 4-bit mode LCDCMD 1, 40 ' Set 2-line mode with 5x8 font LCDCMD 1, 8 ' Turn display off LCDCMD 1, 12 ' Turn display on without cursor LCDCMD 1, 6 ' Auto-increment cursor LCDCMD 1, 1 ' Clear the display PAUSE LCD_Pause RETURNPost Edited (Paul Sr.) : 10/26/2006 12:49:05 PM GMT
Your right I should have removed the sub call from main.· That was a mistake when I pasted into the forum.· The original was
' {$STAMP BS2p}
' {$PBASIC 2.5}
Main:
· GOSUB Init_LCD
· LCDOUT 1, 1, [noparse][[/noparse]"Hello World!"]
· STOP
Init_LCD:
· PAUSE 1000··························· ' allow LCD to power-up
· LCDCMD 1, 48························· ' Send wake-up sequence (3x)
· PAUSE 5
· LCDCMD 1, 48
· PAUSE 1
· LCDCMD 1, 48
· PAUSE 1
· LCDCMD 1, 32························· ' Set data bus to 4-bit mode
· LCDCMD 1, 40························· ' Set 2-line mode with 5x8 font
· LCDCMD 1, 8·························· ' Turn display off
· LCDCMD 1, 12························· ' Turn display on without cursor
· LCDCMD 1, 6·························· ' Auto-increment cursor
· LCDCMD 1, 1·························· ' Clear the display
REturn·
Your code and the code above does not display "Hello World" when using a BS2p24/BOE and LCD Appmod revision A.· I can get the display working if I use·use a BS2.· Even the LCD_AppMod_Demo.BS2 found on the·LCD Terminal Appmod page is not functioning properly.· However, if I use a BS2/BOE·the LCD functions as expected.
The attached code function perfectly with a BS2\LCD and was working on a BS2p\LCD.· To make matter worse, I've had many different LCD Terminal Appmods on several different projects.· So I'm not sure if this particular LCD ever functioned properly with a BS2p since it was attached to a BS2 project.
·· I can confirm that the following code works on our LCD AppMod on a BS2p24 as I just tested it now.· Try the attached file and see if that works for you.· Take care.
Chris Savage
Parallax Tech Support
The attached LcdAppmodDemo.BS2 is not working with my BS2p24/BOE - LCD Terminal Appmod setup. However, if I swap the BS2p for a BS2 it works fine
I found another LCD Terminal Appmod lying around plugged it in and it has the same problem. It works with a BS2 and not the BS2p24 using "LcdAppmodDemo.BS2".
·· This is strange, indeed!· I cannot reproduce your results at Parallax with the same exact hardware and software…What sort of power supply are you running this from?· I know it’s grasping, but something has to be the cause.
Chris Savage
I can send you my LCD/BS2p/BOE if you like.
·· Contact me via e-mail regarding that.· My address is in the E-Mail icon to the left.
Chris Savage
