Ping sensor at higher frequency ?
Hi all,
The Ping ultrasonic sensor is measuring at 40kHz. To make an echo sounder based on the basic stamp which can measure the depth in water, like lakes and rivers, I'm looking for a solution where the sensor is IP68 watertight at the front side, and the preferred measuring frequency is around 650 kHz. Is there somebody with an idea or suggestion how to realize this ? Has also to work with applications where the bottomlayer is a little bit "fluffy" caused by floating sludge.
Thanks.
Dries Nelemans
Thanks.
Dries Nelemans
·· You’re going to need to use the type of transducer used in a ‘fish-finder’ and probably create a custom controller based on an SX chip to send and receive pulses at that frequency.
Chris Savage
Parallax Tech Support
Me again. Most of the ultrasonic depth sensors I know of bounce the ultrasound off the top surface of the water, from ultrasound passing through an air column above the water. Chris Nafis posted a nice project using the Ping for that purpose, and also for snow, which can have a "fluffy" surface. www.howmuchsnow.com/ping/. You can also find info on that project with a search of the forum here.
Why 650khz? The attenuation per unit distance is quite high at that frequency. The wavelength at 40khz is laround 0.7cm, and that sort of defines the limit of resolution. Although a phase sensitive system could do better, given a non-fluffy signal.
Are you thinking of having a sensor immersed in water (Your comment about IP68) at the bottom, with reflections back from the top surface? . There might be something you could salvage from an ultrasonic cleaner tank or an ultrasonic vaporizer. Those are impedance matched to transmit in water.
Unidata makes a "starflow" system that sits on the bottom of a water channel and uses ultrasonic doppler to measure the flow rate. It also measures depth, but I think that is hydrostatic.
Tracy Allen
www.emesystems.com
/Dries
Dries Nelemans
Tracy Allen
www.emesystems.com
/Dries
Dries Nelemans
One alternative to echo depth sounding might be to monitor echo phase instead of echo time. If you have a pair of transducers, excite one with a sine wave, and hook the receiver to an oscilloscope, synced to the transmitter. The phase seen on screen will be related to the depth to the bottom of the channel (a constant?). That would be modulated by the depth and density of the sludge. The circuitry required would be a synchronous detector feeding an analog-to-digital converter. Each zero of phase represents 1/2 wavelength of the operating frequency. Is is not an absolute meaurement like echo, but more like an incremental encoder wheel.
Tracy Allen
www.emesystems.com
Depending on how much time and money you want to put into the sensor design/construction/testing, you might consider a ready-to-go marine depth sounder with dual-frequency transducer. They are particularly set up to see both the 'fluffy' layer and the 'solid' layer underneath.
Many of the Lowrance brand (and others) have serial data output which the Stamp's handle very easily.
I've used this setup to measure the sludge layer in municipal sewage lagoons.
Cheers
Tom Sisk
http://www.siskconsult.com
Didn't found time to check the hexamite information but I will do soon. I prefer a "complete system" that if possible directly can be connected to the basic stamp. Maybe this is an utopia....Measuring phase shift instead of time, maybe a good idea when echo fails but I'm afraid that developing this will take a lot of time
/Dries
Dries Nelemans, Holland
Can you tell me more about the municipal sewage lagoon application ?
Have you measured the sludgelayer in water, with the sensor immersed in the "clear water" zone.
BR, Dries
