Serial voltage levels
I'd like to hook a propeller to a GPS module that does TTL RS-232 (0-5v).· Can the propeller work with this directly or do I need to put a 3.3/5v level converter in between the module and the propeller?
Steve
Steve
220 220 GPS I/O >----/\/\---o---/\/\---> GND | o----------> Propeller I/O▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Steve
why wouldn't you use the simpler 4.7k-10k series resistor solution in this case?
I'm wondering because I'm interfacing a Propeller to the CmuCam2, which uses 0-5v TTL at 115200 bauds. I've been putting a 10k resistor in series with the cam's TX pin and nothing at all on the RX pin. I've only done sme testing with the cmucam, sending some commands and receiving some packets, but I haven't had any trouble yet.
Post Edited (acantostega) : 10/13/2006 10:13:41 PM GMT
substrate noise levels down on the IC.· Using a 4.7k to 10k series resistor assumes you are relying on the substrate diodes for part of
the current path which might lead to unwanted noise.
The divider method steers away from this.
If the Propeller I/O is set as an Input and the GPS I/O is set as an OUTPUT, then a LOW· (0V)·on the GPS Input to the divider will show up as a LOW (0V)·on the Propeller I/O
If the Propeller I/O is set as an Input and the GPS I/O is set as an OUTPUT, then a·HIGH (5V) on the GPS Input to the divider will show up as a·HIGH (2.5V) on the Propeller I/O
If the Propeller I/O is set as an Output and the GPS I/O is set as an INPUT, then a LOW· (0V)·on the·Propeller·Input·to the divider will show up as a LOW (0V)·on the·GPS I/O
If the Propeller I/O is set as an Output and the GPS I/O is set as an INPUT, then a·HIGH (3.3V) on the·Propeller Input to the divider will show up as a·HIGH (3.3V) on the GPS I/O
If the Propeller I/O is set as an Output and the GPS I/O is set as an OUTPUT and there is a collision, the maximum current through the linking 220 Ohm resistor will be 15mA ; minimum·7.7mA
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/13/2006 10:58:00 PM GMT
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
